  • Replies 2.1k
Posted Images
quote of the day...
Considering how much Honda pay Jenson Button you'd think he might be a bit more positive after races. Jenson, mate, nobody really enjoys seeing a ginger beard up close, so make it easy on us and say something less whingey while we're shielding our eyes. You may have a boss who speaks with all the boyish optimism of a Christian Youth Leader, but that's no reason to take the opposite tack.
You don't have to call the car crap - we can see it's crap.
We were standing next to these 3 yobbo piss heads watching the race....for some reason they thought Webber was 3rd/4th the whole race....was f**kin brilliant when the commentator on GP radio could be heard to say 'and Webber is in 13th...'
Just got my hands on a sample mkv file of what i'll be watching for the entire 2007 season (itv telecast).
It has 4 independent windows, top left is camera angle 1 (its blank for the screenshot only - don't know why) bottom left is camera angle 2, top right is track info (temperatures, location of cars, track status etc) and bottom right is the timing page with driver positions and sector times etc.
Probably the most fascinating way of watching the race, just means i'll have to watch ch10's coverage first then this format 2 days later (takes that long for the person to create it).
"By the second half of the race Giancarlo was already in the hotel," Briatore is quoted as saying by German specialist magazine Auto Motor und Sport. :dry:
Looks like he is surprised their season opener was bad...guess how the rest of the season is going to go with a Rosberge esque rookie and a delicate Roman :)
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
