  • Replies 2.1k
Posted Images
Or they could just fuel him slightly less so that he qualifies slightly higher (5-8 instead of 8-12) so that he has better track position in the first stint because it's easier to hold someone up behind you than it is to overtake someone doing a similar lap time.
yeah good point. but i think the problem with that he may not actually qualify better than that with the same car and setup.
team stratergy will work out. it will fall into place at some stage. Almost did in canada.
Quoted from greman newspaper and translated into english...
Sounds like a typical Joe Saward piece of bullsh!t. He basically makes up whatever he wants & reports his opinion as fact or occasionally as conjecture. More often than not he is completely wrong.
As the quote goes "Writing fiction is great, you can make up just about anything."
He is one reason why I never used to buy Motorsport News. Although now you don't have to pay for it.
It does explain to some extent whay we havent seen any sort of aero upgrades recently... Mclaren, BMW, Williams even Honda have introduced parts recently. You'd think Ferrari would be right up there pumping out aero pieces to keep up with Mclarens rate of development, but no. This week is the first week in some time that they're adding new aero parts on the car.
Just seemed like a logical explanation...
Well it's plausable. Which is the kindest thing you can say about some of his stuff.
Unfortunately for peeps like me Ferrari are dropping the ball in many areas this year and it starting to show up now the season is getting serious. I know of maybe a big aero upgrading coming but not until August which is way to late in the year. I think maybe some of those key members leaving is starting to filter through
Im with you there, typical Mclaren, more data for Dennis's mob. Calling Honda a 'B' team is a complement going on there discraceful performance this year...maybe the 'Z' team would be better.
Well it isn't actually Ron Dennis' fault. More of a case of getting a deal done whilst he cane & whilst it can benefit McLaren. The rule shouldn't have changed - each entry should be required to use a different constructor. Back in the day companies such as Lola & March supplied heaps of chassis.
& yep Honda suck wang this year. Hopefully they will improve.
Lewis Hamilton stacked his Vodafone go kart at an event today!!
ahaha, lets hope thats the only wipeout he has this year!! it was a total noob mistake! :laughing-smiley-014: :laughing-smiley-014:
check it, helmet cam style. :D:)
http://www.youtube.com/watch?v=K_4uhYoMEX0
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
    • Thanks buddy.. the standard one needs to be about another inch or inch and a half longer. Thanks anyway
