im doing nissan gazelle with sr convertion,l but its a lot of work and cost about 5g already and probly 8 by the time its finished did i mention its been 11 months since i put the sr in and only first ran it 2 weeks ago. anyway what ever you do by the best condition car you can find even if it 3 times the price of a cheap fingerd one it will save you a lot of trouble in the end, ie dint, shit paint, rust, interior,suspention and bushes
just my 2 cents
  • Replies 44
Posted Images
Haysey, where are you getting all these pics from? Friggen awesome! :(
Has anyone ever done up a R31 Skyline wagon?
According to redbook they have the same kerb weight as an R32 GTS-T. A turbo on the RB30 would make it bloody quick in a straight line. You could probably drift it aswell :P
Keep em coming :D
just my usual hunting of the net, coming across these things, always liked sleepers, a mate has a old 71 corona he insipired to put a rotor in, maybe one day...
this cressida has a supra engine in it
Yeah, s12 silvia coupe, but an FJ20T or CA18eT would do it for 14's, could probably even do a nasty NA SR20 with a stripped out interior. I have heard of RB power s12's but I reckon that'd be heaps of work..
I know the pic isn't much of a sleeper but I love it..
Edited by SKY32
Suzuki Mighty Boy with a Pulse Jet Engine :P
Or just a 20kg Titanium frame with a Pulse Jet Engine works fine too :rofl:
omg we musta imported half the mighty boys on that site.
my low budget not so sleeper is a $600 AE86 with a $1000 CA18DET.
get an old volvo and stick a V8 in it or a 1jz , front cut for one of those is only $1400.
Volvos have big ass brakes and massive engine bays, not to mention the diffs are dana's on some of the 70's models meaning it's not too hard to get LSDs and different gear sets and they are super strong.
Nothing better than driving this sort of sleeper, I have experience. I used to love driving my old unit around.
As you can see lots of room in the engine bay.
any old datto that came with an L series 6. drop a v8 in....matter of fact i have a midly worked 253, that only had 5 months of driving before the car was written off. that comes with all cross members and mount to drop in a L6 powered car.
v8 specs:Worked 253, machined by Trapnell Race Engines, ACL Race Series flat top fly cut pistons(60 thou) peened rods, balanced and blueprinted bottom end, New port matched Speedmaster single plane manifold, inlet and exhaust ports tidied, 20thou off heads, new Speedpro billet camshaft, new lifters, new double row timing chain, new w/pump and timing cover,Hi volume sump, double valve springs, block hugger extractors, Alloy rocker covers, Hadfield bellhousing, supra 5speed, Built to run straight LPG, but also suits petrol, 5 months old rebuild. Detailed in black and kermit green.
Selling due to crashed car, no damage to engine or gearbox.
Haysey, where are you getting all these pics from? Friggen awesome! :P
According to redbook they have the same kerb weight as an R32 GTS-T. A turbo on the RB30 would make it bloody quick in a straight line. You could probably drift it aswell :)
Keep em coming ;)
My 2c: this is the best idea yet. Max sleeper doofus grandpa value, cheap as f#$k, good engineering.
There's a Ford Anglia with a worked SR20 in it running around NSW.
It's a Ford (keeps the olds happy), they weigh about 800kg and they look so granny standard that no one is ever gonna take it seriously.
Power to weight ratio is insane.
I've also seen an Anglia with a worked Ford 4 litre six in the front.
Major firewall mods needed but it went like a rocket and handled too.
This second one would definitely keep his olds on side but realistically I don't think any of the projects mentioned in this thread could be done for 5 grand.
If you can prove me wrong though I'd love to see the results.
i reckon the gazelle may be under the budget.
you can buy em with shagged engines for sub$1000.
spend the rest on the engine of your choice.
and afaik, all the R31 and S13 gear bolts up to it, struts, brakes, etc.
so it could be the cheapest of the lot.
rotor powered S12 ftw :(
the old C210 skyline coupe i had was converted to v8/5speed and LPG for well under 5k.
dads old 620 datto ute.... we converted it from 1.5l 4 speed on the steering column to 2L 5 speed and twin carb, for under 1k..... if you can do the work yourself, conversions are cheap as chips.
Theres a guy around here with a VS ute with a 1jz and massive high mount. The ultimate of work utes.
theres a guy near here also, lives around logan im sure. damn it hauls ass. VS ute, pursuits and is a sleeper as they come. nasty weapon though.
Edited by silverbulletR33
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
