Kws At The Wheels
219 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 152
Posted Images
I'm ~4weeks away from just under doubling the power its currently making. :(
ok everyone, take note. on the 10th of january 2006 joel said he will have close to doubled his power so aiming for 350rwkw? so on the 10th of Febuary 2006 we want to see they dyno sheet! :(:)
lol.. It will be nudging close to 300rwkw. :)
Fingers crossed.
Ash.. Did a comp test the other day as the motors now clocked 50k. Came up as it did when it was bran spankin new. Not a single variance between the cylinders. :(
so joel if you car is of the road atm its making no power so what is double that:)
It's still nothing!!!
All the best on the "next phase" of your project Joel, look forward to the results mate.
lol.. It will be nudging close to 300rwkw. :P
Fingers crossed.
Bah, this thread should read how much torque does your car put out....
mines eleventybillion so where do i mark down that ive got the biggest wang??
Edited by Bl4cK32
lol.. It will be nudging close to 300rwkw. :rant:
Fingers crossed.
Ash.. Did a comp test the other day as the motors now clocked 50k. Came up as it did when it was bran spankin new. Not a single variance between the cylinders. :)
thats awesome, will have to give mine a comp test sometime soon.
Dunno how long it will be til mines making more power now that i've bought the house, mind you i basically have everything but the cams sitting here, it all just needs installing and tuned!
Are you going to shead any light on your plans?
there will be grunty vlt's on the road in the next couple of months
aswell by the looks, all over 350rwkw, twin and single cam manual and autos
still RB power:)
cheers
darren
even so commodoor drivers think there car is good cause of GM forgetting its because of Nissan that there car is so good
irrespective a VL is what it is. RB POWA! :O
Darren, Good to see. Is one of those the bloke you were talking about at the dyno day? Basically the same setup as yours but DOHC?
Sounds like you're talking about either Rob (white) or Corrans (Marrone..something) VL's? Darren. Still love your car from the Smasa cruise....those slicks...lol....liberty... :) If you're talking DOHC im guessing that's Alex's?
Edited by DC_GTST
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
