  • Replies 228
eyy bro when did ya do your engine??
your wheels were just looking and goin sick eyy?
what you do excatly to it?
join the club my donks fuct 2 :dry:
he doesnt know :O he thinks it was too much bee-r but i think it had something to do with the fact he was playing around with the injector setup on the pfc h/c ahaha
#5 has a nice compression of like 60 hehe :(
despite what people think, ignition cut rev limiters like bee-r ones are quite harsh on engines. as you can imagine a huge flame going through the head/manifold and turbo doesnt exatly help things. when i had one on my sr20, i broke 3 rocker arms simply because of the strain it places on the head. Since i have gotten rid of it the engine has never been better
this is true, however the Bee*r limiter only cuts sparks at red line, unless you hold the red line for extended time, the damage will be minimal and gradual.
What Exactly is a Beer Limiter?? can someon Pls explain thanks
-JuLiuZ
what i gather from what ive seen and read, its a devise that cuts spark at a preset rev limit or at the rev limiter, so when you hit that point it doesn't spark, but dumps mass fuel/air into the exhaust and then (i think) sparks as it is exiting(?)
this is why it pops and farts and shoots flames out the zorst and thats why it puts strain on teh engine as exploding fuel/air expands very rapidly, stressing and fatiguing metal
So it's Sorta Like Anti-Lag wif the Back Popping Action eh???? hehe :)
-JuLiuZ
So it's Sorta Like Anti-Lag wif the Back Popping Action eh???? hehe :D
-JuLiuZ
not really, antilag retard timing and works throughout the rev range and does not cuts sparks, allow some fuel to escape....hence more damaging
where Bee*r cuts spark at red line, so cold fuel will exit and detonate at the manifold instead.
I dun get tho, I thought fuel will detonate at certain pressure anyways, the sparks are just there to give a more regular timing
it would but normal combustion engines dont create enough pressue, but thats how diesel engines work, no spark plugs in them
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
    • Yeah, Duncan is helping sell me back to Android devices. I've hated the whole Android head units due to their speed issues. Even in my old Hyundai Kona (2022 model), it behind the scenes was Android, and slow and shitty to start up. Once running wasn't bad, but still a good 15 to 30 seconds.
    • My roof rails are off atm on the E39 until the rust is fixed. I did find another little bit of surface rust under the rails when I took them off. As @soviet_merlin said I'd just leave them alone unless you're planning on ensuring they're properly sealed. I was on the fence about leaving them off as the delete is still a thing in BMW E39's but I feel like the car is missing something (er, it is, der) with them off and I'm looking forward to putting them back on.
