The R32 RB25DE VRS kit is around $275.
It includes all top end gaskets consisting of inlet manifold gasket, plenum gasket, exhaust manifold gasket, rocker cover gaskets and valve stem seals. There may be more thats the most important one off the top of my head. :cheers:
If I was to buy JUST the valve stem seals from Nissan they wanted $330.. lol
i have a question for you guys i have an rb30 block and a rb26 head i want to put them together is it possible if it is how do i go about doing it and where do i source the parts to do it thanks alot.
dude... you've got 99 pages here which pretty much give you the ins and outs of exactly how to do it. There is also a guide floating around (i think Cubes did it). Infact there is a link in his post above this!
Andrew
I thought I'd update ppls..
Loading up say 4th gear at 1500rpm starts to see boost quickly then it goes flat and the turbo sounds strange, if I hold my foot in to it the turbo starts to make a really strange noise (almost a popping noise) then the car begins to jerk around. nasty pasty. :)
I have never actually held my foot in to it when it has that flat feeling so I haven't heard the popping or felt the jerking before. Never again will I do it. Sounds really bad.
Not to worry, its never really in that zone anyhow. :cheers:
A good excuse to pull the little terd off. :D
Welcome to the world of compressor surge:cheers:
Andrew
thanks alot for your help, wha tkind of power have you seen this conversion produce, i am living in the united states and there is not alot of people that do these kind of conversions so i jus wanted to try something new, again thanks alot for your help guys.
What, you guys had enough of buying every sr20 on the market and driving the price up for the rest of us? Want to move onto something else to overvalue do ya?
(not that i won't sell you a rb30 short motor...)
guys...
if i through a rod in my 25det could i just bolt on a rb30 bottom end?
would like to keep compression same maybe a bit lower...
im running 18psi through standard motor and i know it will fly apart soon, hahahaha
any help would be great
thanx
This would have to be one of the longest threads I've ever seen and by far the most useful.
Cubes and Sydneykid have been saying for quite some time that cams should become before upgrading the plenom, in particular TOMEI 256 cams. I have a Rb25 head with VVT that is ported and polished (mirror finish).
Has anyone used these cams in a 25/30 and has dyno results to show?, I'm interested at looking at the mid range Hp and Torque.
i am sorry if this has been asked but can you use SR20 pistons when building up a rb30det?
and does anyone know a good place to get rb30e pistons from.
thanks
I've read about using sr20 pistons in them before, Blue r33 with 26 head 30 bottom that was in nzpc a while ago was using them. I'm still not sure why anyone would do this in preference to using forged 30 ones, needing to buy two sets of sr pistons bumps the cost up a bit.
A bit of the topic, ive got a rb30det in my R32. Has a stock bottom end with a R32 RB25DE head. Ive got an old school t04 on it with a smaller exhaust housing. Its running out of puff around 300rwhp.
Just wanting to know what turbos u guys are running and the power your making, and how the driveability is with them? Im after something that will produce 450rwhp with a good power band?
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
