Ive been runnin around in my RB30DET for about 9 months... 30,000km or so later and she it still going strong... Mods are
RB30DET 25 head
PFC
Exaust
AVO Stage 2 intercooler and 3" piping
Sard FPR withstock injectors
T4 turbo 60 ar with rx7 rear 300zx rear housing
Walbro 500hp pump
Taking it to UAS to give it a tune methinks.. any ideas on what power she should make ??? I would like 250rwkw :( thats the max for stock injectors ???
got the car to scott @ insight for a tune last night
its been running like shuit latekly
he started all over again. fixed mapping etc etc
11psi. he said roughly 320rwhp
i be happy. rb30det is the way to go i say.
torque monster. go the stock bottom end!!
Nice man.. what turbo specs??? stock injectors ????
nice one mark you bastard. pete told me he reckons it may chirp seconds now. is that true?
fix your clutch, and also I'm hanging for my turn. you've driven my sick 31, now it's time to swap!
quick question:
the RB30's in the VL's were used with LEADED petrol right?
and to use unleaded they needed some additive to protect the rings?(not sure if this part is right)
so do you need to buy different rings when rebuilding the stock bottom end for a det conversion?
Gary said stock rings, bearings...etc...
so can someone explain the reason why an additive is required for older cars to use Unleaded fuel?
cheers
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
    • I like their veal scallopini.
    • Definitely a hearty eater when we go out, I consider these meals my cheat day as I've been watching my calories in and calories out pretty hard since my little fun size stroke, I've gone from a fat boy of 89 Kg, I'm only 165cm tall/short, down to a almost semi lean 73 Kg over the last few years, I'm currently around 17% body fat which my doctor is very happy with, but, my goal is to slowly get down to and maintain 15%,so yeah, I want all of the protein, carbs, fats and sugars when I go out for a binge
    • There was a great one on Victoria Rd in Gladesville too back in the day. I can only assume GTSBoy is thinking of the mill up on the wollondilly, no restaurant there any more but they have restored the original steam engine on site and run it every few months, have an annual steampunk festival etc @The Bogan, you came to the wrong town for restaurants. we have a few reasonable asian and indian options but the Paragon is as good as it gets otherwise. That brewery is apparently just opened, been meaning to give it a go some time. The Highlands have plenty of fancy options but I suspect you are more a hearty eater than fancy eater
    • Thanks for coming back to post the update, maybe it will help out the next person!
