Yeah i have read some... Its just that its so damn big, there's so many different conversations about what i wanna know its all just a little confusing... Basically, i've got a perfectly good RB30ET block with f**k all km's on it, im planning on puttin the R32 RB25DE head on it with all aftermarket bolt on's... I just wanna know whether the E and ET blocks are basically the same and whether i just need to use the RB30E spec pistons to get the appropriate compression ratio??? If not, what would be best???
If you are thinking about putting the head straight onto the rb30et block standard then it wont work. HOWEVER if you change the pistons to the NA spec then it will be ok.
The pistons in the rb30et are too low compression and the NA pistons should be used.
If you rebuild the rb30et block and put forged pistons in it to raise the compression up to the same for NA then it will be good.
Guys the RB30 vented coil pack covers are going to be cut soon any suggestions as to what is going to be on there would be great i have come up with at least a few say 2 or maybe 3.
"RB30 DET"
"RB30 DOHC"
"RB30 TWIN CAM TURBO"
"RB30 GODZILLA" for 4wd ones :wave:
"RB30 TORQUE MONSTA"
"RB30 DET"
"RB30 DOHC"
"RB30 GODZILLA" for 4wd ones :dry:
Maybe a "RB30 DOHC TURBO"
or " NISSAN 3000cc DOHC TURBO"
What did it say on the stock RB20/25 covers before?
r32 rb25de head stock with det valve springs big front facing plenum 80mm throttle body q45 afm. bottom end stockish rebuilt. shot peineed rods, and aftermarket rings, crank collar, either rb25 oil pump or n1
what would this turbo go like on it?
called a gt45
Inlet (Exducer/Hot Side) T-4 Flange 70.1mm x 82.55mm (2.76" x3.25").
*A/R 1.05 Exducer
*A/R 0.66 Compressor
*Cooling/Lubrication Oil
*Outlet (exducer/hot side) 4.25" V-Band
*Inlet (compressor/cold side) 109mm (4.25")
*Outlet (compressor/cold side) 86mm (3.38")
*Compressor major diameter 98 mm
my goal is 400-500rwhp. On a 20det modded manifold When would this size turbo start spooling and when would it hit full boost? 15psi. unsure of what exhaust manifold yet, either a 20det stock modded to fit the t4 flange or a whole custom mild steel one.
Can anyone help with some info on this? is this turbo 2 big?
Thanks
called a gt45
*A/R 1.05 Exducer
Thanks
Too big, by a long way.
:D cheers ;)
PS; Shot peening used RB30 rods achieves almost nothing, spend the money on a set of ARP rod bolts
"RB30 DET"
"RB30 DOHC"
"RB30 GODZILLA" for 4wd ones :)
how about "hey mr. policeman, i want a defect" :)
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
