Shane if that bloke told you not to do the oil return from the back of the head....hes an idiot. We didnt do all the modifications as SK had stated in the guide, because my old man is so farking worried about oil starvation for the top end, well bingo we have oil problems houston! We did the oil return from the back of the head, not full size though, blocked off the rear feed and put a 1.5mm in the front when it should have been a 1mm and we didnt oversize or shape the return holes to the sump. So now we have to run a pump from our 4.5l catch can to the sump to help get the oil back into the motor, so we dont lose it everywhere.
Not saying yours might be like that, but ours is and i believed SK and my old man didnt and now until we pull it down for rebuild and more mods, we have to put up with that problem with our bandaid fix. I hope your setup doesnt yield the same problems as ours.
Anybody has experience with HKS 2530's (or Garrett 2860r -5's) on an RB26/30?
Aiming for sooper-dooper response (e.g. Mines car) and say 550-600hp at the flywheel.
I want to keep twin low-mounts. I know they are perhaps 'small' for the 3 Litre. Intended use is for a weekend street car - bit of street - lots of short track/hillclimbs/motokhanas etc.
Achievable? Anyone actually running this combo?
That's the combo I want, just need the bottom end done.
Well mine is nearly done.. so time to actually buy the Turbo's! :D
The question of going between 2530's and GT-RS has been a question I just can't answer for the last few months... and I'm getting very close to D day...
I'm still leaning to 2530's... also keeps the power down away from the 700 odd that the GT-RS will most likely make (= break things)
Michael, ive got full confidence in what john recommends, and i think it could be different if i was only running an RB25 head, not sure though. Time will tell though.
Matt dont be soft, get them GT-RS's and you wont regret it! :)
From the figures SK has been stating, the RB30 will generate 20% more power at the same RPM as an RB25, so i wouldnt want to run the 2530's as they'd be, "too responsive" :P
From the figures SK has been stating, the RB30 will generate 20% more power at the same RPM as an RB25, so i wouldnt want to run the 2530's as they'd be, "too responsive" :)
Don't be concerned. Select turbo's for your power goal and go with that. 300+rwkw isn't going to get going before 3500rpm minimum anyway.
Hey Cubes, I'm not sure what you're saying:
Do you mean Don't be concerned about the response? ie Go for the GT-RS since I won't see anything below 3500rpm with either combo?
Or do you mean Don't be concerned, if 2530's make the power goal I am after then just get those.
And how come you say I won't get them going under 3500rpm anyway? To exaggerate for a second - if I put GT-SS on a 3Litre (not that I would), wouldn't you think I'd see full boost under 3500rpm?
If I manage to get 2530's on near to full boost by 3500rpm and go to 7000rpm and make 550-600hp I think I'll be a very happy camper - but maybe that's a little wishful...
:P tempting...
Seriously, do you think they would be 'too responsive'? I'm used to a supercharged V8 which is more or less instant response and you just control that with your right foot. I would have thought it would be great?
I'm not going for fuel economy here...
1. Do you mean Don't be concerned about the response? ie Go for the GT-RS since I won't see anything below 3500rpm with either combo?
2. And how come you say I won't get them going under 3500rpm anyway? To exaggerate for a second - if I put GT-SS on a 3Litre (not that I would), wouldn't you think I'd see full boost under 3500rpm?
1. Thats it... Don't be concerned with too much response as its not going to be insane supercharger style response.
2. To be honest I'm not familiar with twins on a 3ltr but I wouldn't expect you to feel a hard punch below 3500rpm for over 300rwkw. It appears you can pull roughly 600-700rpm or so off the spool of an rb25 or rb26.
Personally, yeah i do. I think they'd be on boost 24/7.
What we need is, is a test bed so we can compare turbo's. I've been thinking about teeing up one of the garrett suppliers to help me test different turbo's and get some results. Same engine only thing that gets changed is turbo's. Otherwise all we can do is speculate.
Does anyone know cost wise, how similar would it be for rebuilding an rb25 as compared to an rb30 conversion?? There is a chance my block won't be able to be used for a rebuild, so a conversion is a possibility for me now.
Once you drop the rb30 in you will see that you don't need to accelerate it up on boost to leave traffic.
Go for a drive in a rb30det and you will see what I mean. Even with a small turbo its VERY easy to control spool as the torque of the motor lugs the car around very well and simply doesn't require you to crack open the throttle.
Whats wrong with boost 24x7 anyway? Put your foot down and its off. :P
If it makes the power you are after whats the point of running a turbo's that flow 700-800hp worth of air when you only require 500-600. Its a lot like over clutching a car.
Remember the whole idea of the rb30 is average power. If you don't want boost being made earlier and have the car acelerating off idle at a faster rate stick with the rb26.
There's a bloke thats done a 2.9ltr stroker. So close enough to 3ltrs.
http://www.skylinesaustralia.com/forums/in...t&p=2396511
He's running GT-RS's, as you can see its no where near too responsive (4500rpm) but sounds quite linear and a reasonable package for the power being made.
I put bigger injectors in and the car ended up making 406rwkw @ 18 pounds on pump fuel. Any more boost and it only picked up small amounts of kw and started to heat the air, not sure if the turbos are maxed out or if something in the induction setup is causing a restriction... not sure if my cooler is big enough. I've got another dyno sheet but its done in shoot 8 insted of shoot 6 so the torque figure is different due to the different ramp rate?? ( i dont know much about dynos). The power curve looks identical, just goes a few kw higher... To drive, the car is nice and broad and controllable in power delivery,pulls well from 3000 rpm and hard from 4500 through to 8500rpm...
Ive two more cranks almost ready to go, and more started for those that are interested. Please PM if you are intersested, so we can discuss options. It can be set up with std rods, or after market, 21mm or 22mm pins. My car will be on display at Adelaide auto salon, as will a 2.9l short engine. As usual any questions, comments or ideas just shoot
Based on my experiences, 2530’s on a 3 litre would be like 2510’s on a 2.6 litre, which was a very popular selection for a road/circuit GTR. Highly responsive, without feeling too choked at high rpm (7,000 rpm or so). You could easily get 1 bar at 3,000 rpm at WOT, but if you don’t want/need boost then, don’t open the throttle so much. I very nearly went for a pair of 2530’s on my first RB30, but the old T04 came up at a good price.
I would really like to see an RB30 with 400 rwkw using 2530’s, it would be a real high average power weapon. Keep in mind that 2530’s are used on the re-released R32GTR Z Tune, which uses an RB27 with a 264 inlet cam and a 272 exhaust. The 272 exhaust indicates that maybe they used the longer exhaust duration to smooth out the boost hit. Which is a trick you could use on an RB30.
:( cheers :(
Edited by Sydneykid
Well your wrong. Boost is controlled by the right foot. Im running a rb20 highflow on mine and its a simple matter of keeping off wot to control how much boost is made.
I can put my foot down and run whatever i want ie, my ebc is set to 16psi, but i cant run that much as my coil packs are shagged, so i can go say 1/2 down on throttle to get to 0.5 bar which will still pull to redline.
I agree with cubes, choose the turbo to suit the power u want, not just get a gt35r (or larger) cos thats whats recommended on a 3lt motor.
Could not agree more, get the smallest turbo possible that will achieve the power you want, area under the torque curve wins races on the street every time, nothing worse than having 700hp and having to look like a tool to beat a standard v6 commodore with big revs/noise and wheelspin.
Hey, sorry if this has been covered but there is 213 pages so a bit to much to look through. Just wondering the differences between using an RB25 head on an RB30 and just boaring out a RB25 to 3L. The RB25 block is shorter isn't it? but is there any power differences etc, which would be better basically.
If you don't wanna reply to me a page number would be great so I can at least check out what has been covered before. Thanks.
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
