Well I want the bottom end to be bullet proof. Customising pistons through CP's is only an extra $200 from experience, so why wouldn't I go for that and have the peice of mind knowing that I push the motor to its limits.
No engine is "bullet proof"; otherwise the professional race cars, with their unlimited budgets, will make them :(
The only way round this is to make a 1000hp engine and only use 400hp :worship:
Hey guys im finding that when fitting the RB25 oil / water cooler onto the RB30 block that the filter fitting is quite loose over the RB30 filter thread. Any tips for removing the RB30 filter thread and fitting the RB25 o-ring setup for the oil / water cooler.
I'd prefer to keep it than just run it like the VL/R31 skyline setups.
if you do a search in this thread for my name you should find some info on it. i remember going through this dilema and i posted up some info, but i forget now and i ditched the std cooler arrangement :blink:
thanks shanef! been searching before posting a bit actually, but the answers seemed to point back at using the std RB30 setup which it looks like you've done. I know the RB25 setup can be done tho!
http://www.skylinesaustralia.com/forums/t1...2A#entry2788242
bout half way down theres the info i was thinking about! :blink:
hey guys i just ran into a problem as i was filling my car up with water i found a leak out the water pump. the pump i am usin is a n1 pump and it is leaking out the m6 bolt hole. i have tried using some lockseal but i cannot stop it leaking. it is not under presure so i wanted to know how i can stop tis leaking
thanks
i just found out a couple of my valve guides in my head are split. Nothing major it happens sometimes thats why they make bronze sleeves for the valve guides. How crap is this Hi Octane are the only company i can find who sell them for rb25 head and they want $700 for them. ive got no choice but to pay it. Ahh so much money
Anyone using cooling pro intercooler from Just Jap? looking at the GTR style tube n fin, just wanted to know if the internals are any good or just a bit of shit? Anyone got one, or pics of inside one? Cheers!
Contact JHH performance ( they are in Bris ) - Im sure they can replace them for considerably less.
Cheers
umn so how do i get a compression ratio of 9 instead of 8.3...... i'm sure it's in there but i stopped reading at page 23... i read that using the N/A head will give me compression of 9? how is that so? the n/a head gasket?????
much appreciated.
i'v got an rb30 with only 105,000k's and intend to drop a 25 straight on. looking for about 500hp. if it blows up il put another bottom on!
    • I'm so far behind in the jobs I have to do at both work and home (including car) that I have become immortal. There's simply no way that I can die now.
    • Each to their own I guess  Me, I put just as much time into cleaning inside of the cars as I do on the outside As for getting wet, it is really no different than steam cleaning the carpets at home, apart from the cars carpet dries alot faster than the house, again, I only do it in the hotter months and leave the car opened up for a few hours As I only do it yearly, it is just before I do the diff and gearbox service, so I clean the carpets, then it's up on stands, wheels off, service, clean the undercarriage,  grease the bushings and do a nut and bolt check on everything  Disclaimer: I typically had all the time in the world to kill when I was working 🤣, so spending a full day or 2 cleaning, serving and "looking at stuff" was,  easily achievable, and a fun mental therapy day As for time to kill, I retired last Wednesday, so apart from my physical training, my days are filled with lots of random jobs around the house and garden...."Idle hands are the Devils something something" I am also buying a new house sooner rather than later, I'm actually looking at a potential property tomorrow, I'm looking forward to getting a car hoist as I'm starting to get to old to crawl around under a car, I can only imagine all the undercarriage cleaning and looking at stuff when that gets set up
    • Yeah, I'm not interested in wetting the carpets, and I don't care about brown dirt/dust that lives deep in the pile or underneath. It's not like I crawl around on them in my birthday suit or eat dropped food off them (because there is never any open food in my car). The seats are alcantara (cheap Chinese imitation alcantara, to be sure!) with barely 1" of foam pad behind the surface. That's not getting wet either. Any car that I would be happy to get the interior wet, I would not care to put the effort into.
    • We have one that holds 2.8L of water. On floor carpet that hasn't been touched in 2 or 3 years, will take a minimum of 2 fills of the tank to do a bedroom, and that's going AROUND the bed.   In the cruiser, I used an ENTIRE 2.8L tank, just on the front passenger footwell. But it had some fungus growing, and had been full of mud from being used as a 4WD for many years. I can do that floor again, and it will still pull mud out. However, the water now only looks dirty, not pitch black and leaving full sludge in the bottom of the tank it sucks back into. Oh, and, this is about a $1500 unit.
    • This is mine, works a treat for the cars, suction is good, I use the Bissell clean and protect stuff I have found giving it a good spray and light scrub with the soft brush on the head of the nossle for carpet, and a rub with a microfibre for cloth seats and cloth door trims, prior to another quick spray before vacuuming it up works the best @GTSBoy You would surprised on what it gets out of carpet and seats that actually "look" clean, I recommend that you test drive yours when you have a little time to kill, then post pics of the muddy looking water that I believe you will find
