Two schools of approach. Big boost means low CR as a general rule. High CR then you stay low boost but get off boost response. Fairly simple but off boost I get wheelspin in second out of corners. Haven't seen knock over 12 on the logger with 7 psi and fooling around with the tune and timing.
Question... Using Autronic SM4 in my 33 GTSt (not fitted yet). Looking at my old computer/loom, what needs to stay??? Does the std ecu have to stay connected for a/c, dash, any other ancilleries or can I just cut the loom out all together? I seem to have other wires coming from my std loom going to wiper motor (and some other little orange box back there) not to mention that wires head back from the loom towards the fuse box etc. Anyone else have any of these issues when changing computers?? Cheers for any ideas.
What does one classify as 'big boost'?
Theres 2 people i know of that are running on or very close to 9:1 and 22+psi boost. (michael & noel).
Maybe gone are the days when that rule of thumb doesnt really apply anymore? Food for thought...
you will find they will be running very little timing.
9:1 is great for a street engine running less than 18psi
8.5:1 is good if you plan on running anything over that
8:1 is really a bit low for a street driven car I think
with high CR and high boost you are walking a much finer line. water/methanol injection can be used to supress detonation whilst keeping a nice timing map.
Good points. A decent tuner will work with what he has and extract the maximum from that. Used to be anything over about 20 psi was considered a high boost situation, but that is going up.
Ultimately it is all relative to peak combustion pressures and mean effective pressures (MEP) in the cylinders to calculate the available torque and power.
A classic example is Honda tuners throwing a low pressure turbo on a stock motor and then using that to improve power. Still has good low down, and builds a whack of power up through the rev range. Still a Honda though :thumbsup:
9:1 is still a decently high compression too. Consider the big lump of 5.4L V8 in my BA ute. Only runs 9.5:1 CR and is cammed for reasonable high rpm power.
A MASSIVE cheers to everyone that helped put together the RB30DE .PDF file!
Its taken me a while to find it (after reading 50 pages of this thread) but its all been worth while!
If i bump into the boys who put it together.. Ill have to buy them a beer!.. or 20!
Thanks again fellas!
:yucky:
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
