finally got mine up and running
sounds like a 13B when it revs, i love it :D
had it on the dyno this arvo and on the first power run it killed the clutch LMAO
RB25 box and twin plate on the way
Edited by 2GU UP
R32 RB25DE head
GTR valve springs
mild port work
custom plenum and exhaust manifold
CP forgies
stock rods
35/40 turbo
38mm external gate
microtech
nothing crazy
dunno the comp ratio
Edited by 2GU UP
Sorry I didn't reply to your pm SirRacer; I was meaning to grab some pics today but didn't get around to it.
The RB25 and 20's have a water line that runs from the drivers side of the block around the back of the head then in to the turbo. The line delivers its cool water to the turbo directly from the thermostat housing.
I've had a quick look in the engine manual and its hard to see how the rb26 is setup. :S
Need pics ppls. :P
I've attached a pic of a 26 head. The arrow points to where the rb20 and 25 water return secures.
Ill go and get a picture of my head this week and post it up. So will i simply need to tap into there and run my line directly into the turbo from there, and then once its finished back into the slot in the block?
Is this how they run factory? Im really not sure, where they get their feeds and so on from. I always thought the block one was it and never thought re the return.
The smaller things are becoming the annoying ones in getting my engine going.
Thanks for the help. If you dont mind getting some pics, id be very greatfull. The engines at the fabricator and hes screaming out where to take the water from and i cant tell him at present as im so bloody confused.
Edited by SirRacer
Im normally half intelligent but im mixing things up here.
Have replied in bold
So this is the line that we tap into and run directly to the inlet of the turbo, with the hot water going back into the bottom of the block?
Need pics ppls. :P
Water return would suggest this is where the hot water goes, once its come from the turbo. Very confused
so you reckon that the line that comes out of the block under the exaust manifold is the feed? and that the line that runs around the head is the return?
I'm pretty sure its the other way around, the water returns back into the block, as the water that runs around the block is the hottest part of the engine due to that being where the action is, cylinders. and that the water exits the engine via the thermostat, others have said otherwise but im still pretty sure this is the exit not the entry. and the 26 would be the same as the rest of the rb series as far as the direction of flow goes.
but for a 25 or 20 its simple just fit up to the standard pipe that runs around the back of the head, just where the arrow on the pic is there is a thin tube not sure what size exactly but its the only thin metal tube that runs behind the head, the return back into the block, pretty sure there should be a welsh plug or somthing if its a non tubo block that goes into the water gallery.
if you've got a turbo 25 or 20 block around see where the water return is on them, then look at your rb30 block, if its a non turbo there should be a grub screw kind of thing or a welsh plug or somthing blocking the hole
Heres an email from Rob at Rips in NZ www.ripsltd.com who builds the occasional Rb30
Hi,
I pick up water from the back of the block on the turbo side and return the water from the turbo to the front of the plenim, see pix.
Regards Rob
Is the thermostat housing where the water goes out of once its finished in the engine, or is this the point where it is taken from?
Have attached picture for everyones info
Edited by SirRacer
^^ nice! :rofl:
Think I had a lifter collapse in my DE head a couple of days ago, going to rip the set out of the ol' RB20 tonight and whack them in the 30 on Friday. Also got my hands on a GT35R.. need to measure it up and see if it will fit low mount O_o
thats static 9.7-9.8 dynamic seams to be 8.9:1 which comp should i take into accout?
ENTER YOUR DATA CALCULATED DATA
Cylinder Head Volume (cc) Cylinder Head Vol
(cubic in.) 04.026
Piston Head Volume (cc) Piston Head Vol
(cubic in.) -0.915
Gasket Thickness (in.) Swept Volume
(cubic in.) 31.851
Gasket Bore (in.) T.D.C. Volume
(cubic in.) 03.583
Cylinder Bore Diameter (in.) Gasket Volume
(cubic in.) 00.472
Deck Clearance (in.)
Note: Neg. nubmer above deck, Pos. number below deck Deck Volume
(cubic in.) 00.000
Stroke (in.) STATIC COMPRESSION RATIO 09.889
OPTIONAL DATA
Rod Length (in.) Adjusted Stroke (in.) 03.094
Intake Closing Point (degrees)
ABDC @ 0.050 lift plus 15 degrees DYNAMIC EFFECTIVE COMPRESSION RATIO 08.956
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
    • Just one thing; tapping tapered threads is tricky. Taps are always tapered and you would generally run it as far as you can, but with a tapered thread you have to stop much sooner otherwise the wide part of the taper will run in too far and you will have to thread the sensor in too far too as well (possible that it will never make a good seal) BTW nice wide wheels, I guess the top one is for the back!
