As reported in many posts, I have used the same basic running in process for lots of years and on many engines;
Castrol GTX (the basic no frills mineral oil) with new filter.
Run engine for about 1/2 hr or until well warm.
Change oil filter. Engines can have particles in them that acccumulate during the build/maching proces and they need to be removed from the engine ASAP, these are caught in the oil filter. If you leave them in, the oil filter can get blocked and so it will be bypassed ie; no filtering.
Check the basic tune on the dyno or on the road with portable lambda sensor.
Drive to Bathurst and back, around 500k's, lots of varying conditions, up and down hills, freeway, long climbs etc. Don't rev the beegeesus out of it, gentle but firm, change throttle openings often, no slogging it in high gears with lots of throttle. Much better to load it up with partial throttle openings going up hills.
Drain the GTX and remove the oil filter.
Refill with Castrol Edge 10W60 and fit a new oil filter.
Do leak down test, if OK then final tune on the dyno.
Go racing
Cheers
Gary
What boost levels do you recommend for the first 1/2 hr for a 9.0 comp motor? (GT3582R)
the engines finally up and running, and my god it sounds aggresive.....ive gone 3.5 straight pipe and the turbo spool is insanely loud.
heres a pic.
going in for a final tune on tuesday so will have a dyno chart rdy to go =].
Edited by R34NRG
hey all, im up to page 65 of this thread and plan to read the hole thing.
but just a few quick questions.
what happens if you just bolt the 25det head straight on?? what will or wont work
i dont want the vct as will be using hks cams and gears.
just a few part number quieries.
the JUN crank collar is it 1013M-N001
and the tomie oil restrictors how many does you nead and is it part number 191071
got these numbers from nengun
are nismo injectors side or top feed doesnt say on nengun.
thanks
dan
thanks
dan
Nismo injectors are either top or side feed depending on aplication if you ar ordering through nengun they will send you what ever suits your application depending what you have told them ie. if you order nismo injectors to suit R33 RB25DET you will get injectors that are side feed high impedance.
There is some debate over how to attack the VCT issue.
1. Buy an R32 RB25DE head it bolts straight on and does not have VCT (this is what i have) or use an RB26 head but $$$
2. Bolt the RB25DET head on without running the oil to the VCT as mint_R33 has said he knows of a few VL's running like this
3. If you are buying cams and gears and doing it all at once I think you may be able to just fit them up as you would an RB26 but not 100% on that one.
would prefer to just stay with det head as thats what i have atm. any other opinion on what happens when you just bolt a det head on. what will or wont work
Quick question has anyone used an ATI damper on a RB30 with a 25 head? heard that they won't bolt up on a 25 but not sure hot they fit on the 30?
Lots of people ure them mate,
http://www.skylinesaustralia.com/forums/Rb...ld-t213503.html
I am currently using one on my rb25/30 setup.
I had to do 2 modifications to make it all fit nicely.
1/ Move the Power Steering pulley about 5mm forward on the shaft. My mechanic also welded the shaft to the pulley to add strength. The pulley had to be moved forward as the GTR belts are thicker (4 ribbed) than the GTST belts (3 ribbed). Thus the ATI pulley has the p/steering belt a little more forward than the gtst. I am still using the GTST belts; haven't had an issue.
2/ Lathed up a spacer/hub for the engine fan. A 10mm spacer was made for the fan to move it further away from the ATI pulley, as without the spacer there was only a 0.5-1.0mm clearance between the fan blades and the front of the pulley.
10mm was a fraction too big as it clipped the shroud when loaded at 5000rpm, i just simply trimmed the shroud to clear the fan, but i think a 5mm spacer would have no issues.
Note: Mod 2/ would not be necessary if you are going to use Thermo Fans to replace the clutch fan. My mechanic has a thing that he doesn't like using thermo fans on Skylines as he has found the cars to overheat in the past. His build his rules; that way he's the only one i could blame if something goes wrong :thumbsup:
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
