http://www.skylinesaustralia.com/forums/topic/251669-rb2530-rb30det-vvt-internal-oil-control/
its way too easy to not do just for the sake of laziness. peak hp doesnt change at all without vct but you lose torque below 4500 rpm, something RB's need every bit of. for 5 mins of stuffing around its definately worth it
couldn't be bothered doing the extra work haha & you only lose acouple hp with out so i've been told...
got any links for the threads anyone?
hey people i'm doing this conversion my self & noticed on the rb25det there are an extra line from the head running to the block. what could these be used for? & what do i do with it as the rb30 block doesn't have a tapped hole on the block to fit it...
here's a pic of the rb25det block with the line>>
& here's the rb30 block that doesn't have a tapped hole to fit the line>>
If you have ever driven an rb25 without it you will know it is definitely worth keeping. Up to 10-15kw in the midrange on low throttle conditions.
alright i've worked out that line is the oil drain...
in that info guide it says (The Yellow highlight towards the rear of the block is the water return.
Water feed is provided from a hose/steel pipe assembly that feeds from the opposite side of the block) MY rb25 block has this blocked off do i run a water line from the other side somewhere?
  • 1 month later...
Hi everyone I'm slowly building up my 30 was wonderingwat computer will run a rb25/30 will a normal r33 apexi power fc work or do I need the pro version first time I've mucked around with computers thanks guys
it doesnt work without an oil feed. the solenoid simply feeds oil into a section of the cam which causes it to advance 20 degrees, no oil feed means no vct
Well mine does, and so do a few others I know of - has been checked by three workshops and an engine builder.
But I'm not going to argue with you about it (moreso the fact I don't fully understand why it is working, but it was the engine builder who did the modification without the feed knowing that it would still work).
Edited by cactus
There is a thread on how to supply the vct with oil internally instead of with an outside line:
  • 4 weeks later...
Can anyone tell me if there are any fouling issues with the RB30 sump into a R34. The guide says that with the 32's and 33's it's fine but nothing about 34's. I won't need to drop the engine any lower either as I'm not running the standard plenum.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
