I run BCPR6E NGK's.
They are gapped to .8mm and are the V-groove type.
The V-groove is supposed to improve combustion at lean afr's, unsure if its a gimik or not. :(
I grabbed mine from motortraders, ~$16 for 6.
I've always ran these, never had issues with fouling or missing, the longest I've had a set in for was ~30,000km's. They were still fine, I've had my current set in for ~20,000km's, I will replace them before the next tune.
So much to read and learn in this thread!!!
already read the guide but im sure most of my questions are answered already in here ...
one i do want to know soon though is :
is anyone running GTR rods in the RB30? got a set here and gonna start building one for later down the track .. so just wondering if anyone has them and if they would be better than the std. rb30 rods????
They would be stronger, but they are 31 mm too short.
:) cheers :ph34r:
:) cheers :D
:lol:
i havent looked into the differences in the rods etc as yet but i guess you just solved that issue for me!
I've had a look for aftermarket rods .. only see I-beam rods .. anyone found H-Beam rods for the RB30?
still alot of reading for me to do til i catch up with everything!
I have used REV's and they sh1t all over eagles, honestly dont even bother with an eagle or any other six inch chev rod that is machined to suit they are never as good as a purposely produced item. REVs are really good value for money and I havent had a problem yet, car has produced in excess of 580hp at the wheels, drives around normally with 500hp at the treads and has done 5000ks of hard service and are fine. Another rb30 a friend has with them through a main bearing and upon inspection of all the rods they were still well within factory specs this car has similar hp figures to the previous. I would recommend them to anyone looking to get a good rod at the middle to lower price range, as they measure just as good as some of the more expensive rods I have delt with!!!
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
