TV Networks- which do you watch?
52 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Channel 10 has most of my favourites when it comes to free to air tv...
Simpsons, simpsons and the simpsons...
But i do watch 9 and 7 a fair bit...
My tv is tuned into Discovery most of the day tho as I like doco's the most...
Yeah, I watch House, NCIS, all the Law and Orders and lots of Simpsons and Futurama. Love the West Wing on ABC though and of course, Top Gear on SBS.
Have gotten hooked on Men in Trees on Nine.
Im not a big fan of reality shows, I was a big fan of 10 until them, Now its mainly 7 until H&A then its whatever ABC2 has been drawing me in with its Music and I really liked law&order but when whatsit died.......Olivia is haut mmmm and SBS has its racing too, much better than stuper cars, and you cant go past southpark for Stoopid stuff.
you need an option for those people who download their TV shows in HD from overseas without commercials.
When I do watch TV it is the channel 9 morning news show and that is purely because they have the weather and the time on the screen.
Watch channel ten and seven news.
I have boycotted channel nine news refused to watch, as i went to a function last year and some of the nine news readers were there and they were the rudest snoobiest people i have ever met they thought there shit dont stink. At the end of the day they only read the news.
I'm usually on the net playing fps or eve, or got my head stuck in the engine bay and get my news 2nd, 3rd and 4th hand off the bush telegraph. I'm sick of hearing words like Terrorist, Iraq, Bush and Interest rate rise anyway. The world's gone mad but that's okay, as long as I can't hear the Northern Hemisphere from here, every is good. :laugh:
As for Indonesia, if I want to go look at trees, sandy beaches and clear water, I'll walk down the road.
I call it Ostrich Syndrome !
Really depends whats on at the time. I have to say I prefer Channel 7 News and I also watch 7 for Prison Break. Channel 9 has the cricket and the footy. Alot of the time I have the music channels on foxtel on, or the comedy or CI or the doco channels on.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
