  • Replies 838
Posted Images
I've been playing street fighter 4, I think this may be the first game I ever return...
It's way too basic a fighting game these days with games like DOA going up against it.
HADOUKEN HADOUKEN HADOUKEN HADOUKEN HADOUKEN HADOUKEN HADOUKEN HORUKEN WINNER
worth getting for wii?
hell yeah! I'm using one of the guns I got with house of the dead overkill bang bang box, i have to hold it a bit weird when driving but apart from that it's cool. you aim/look with the gun/wiimote and move etc with the nunchuck. graphics nothing really different over PS2 but it's such a fun game. if you haven't had it on PS2 before then definitely get it for your wii. even if you have had it before get it anyway. the soundtrack = awesome. the level of swearing is up to the standard set by the movie too. "Die Hasa!" "fk you mang" etc.
gameplay is no where near GTAIV neither are the graphics but if you're a scarface fan and who isnt? then you'll love it.
oh, can't find it in stores any more but there's a few on ebay. I'm impatient and had a bidding war and got mine for $35 but the next one I had on my watchlist as backup went for $15. with that in mind you should be able to get it for $20 + post I reckon.
I'll try find it at EB games as a trade in.........else I'll search eBay for it.
I was constantly looking at the cover when I seen it the shops for PS2, but I never bought it, worrying that it would ruin the scareface experience......sounds like that may have been a silly move.
cheers :down:
LOL!
Love that game!
Go nuts and fight through it as fast as you can.
FUUUUUUUUUUUUUUUUUUUUUUUUUUCK!
I just spent the last 2 hours clocking Street Fighter IV on PC, so that I could unlock Akuma and Gouken and it froze on me as I went to save it.
FML.
Armed Assault - like a newer Operation Flashpoint, with smarter AI and 10x harder lol.
Command and Conquer 3 - like EA had read my mind about what sucked balls in the last couple of CnC games and made it exciting fun again, like the first playthrough of Red Alert. First 3D RTS I've really enjoyed and played for hours.
Counterstrike 1.6 (Gungame), even now it's still a blast to play on the net, until some bastard knifes you!#%%$%
Street fighter 4 is waayyyyyyyyyyyyyyyy better then DOA, it puts a refreshing new spin on a classic
Infamous on PS3, its friggin awesome.
I just finished this... it was a great game! I finished playing as Hero, so i might play it again as Infamous... at least then i won't have to worry about not killing civillians! :P
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
