If you pass an EPA with a silencer in, youll have to weld the silencer to the exhaust so it can no longer be removed. One of the conditions of the EPA. Im sure its been mentioned already somewhere though.
Yes it has to be Spot Welded!! but it can be removed!!! its better then being harassed by the cops!!!!
Im just wondering if i have a catback exhaust,front pipe,dumpe pipe from turbo 3'inch all the way with a high flow cat, just wondering if its still legel in the streets of victoria? i know this has been answered before but i just want to make sure if its ok.
Thanks, Geraus
what about if i have a safc ?
would i get dicked ?
You will only get dicked if 1. you have something illegal 2.they find it.
The SAFC is not legal, but if they dont find it you wont get caught. What i'm getting at is take it or, or hide the shit out of it!
went today to get the epa thingo
:rofl:
i was 92db... so yeah failed.
and my safc i just didnt disconnect i took the whole thing about.. like the lcd screen and hid the mainboard in the car.
so if uze have that... try it ?
Hey guys just got my first epa letter! from the police that pulled me over...the letter states i need to get a mechanical check and a noise test.. The current mods i got so far is a FMIC return factory blitz LM and a Turboback exhaust system 3'inch with high flow cat, it ok to go the place with it on or better to take it off the blitz cooler LM? .. honestly my exhaust isnt loud. its a Trust/Greddy PE II as ppl on these fourms would even know there not even that loud...
Thanks Geraus.
Edited by geraus
Cooler will be fine as long as you dont have a pod also. Put your stock exhaust on, yours will most likely fail.
Thanks Geraus.
In other news I got an EPA letter the today, shat my pants. Opened the letter and it was only for flicking a ciggie. Needless to say I was a very happy camper, and will not be throwing ciggies around again.
Thanks Geraus.
Each time you get it tested it will generally be around $40. So you can try with your mods on but Skylines in general just pass with the stock exhaust on, so a very good chance that it will fail with your current one.
I had a look through but couldn't find any information...
What’s the deal with external waste-gates, can you have them as long as they are plumbed back into the exhaust?
I have heard mixed responses on this so just wanted to clarify.
Just another quick question, Can i still pass the EPA test with my stock catback but still have my 3inch front trust/greddy pipe and turbo dump pipe?
bceause i just connect my catback to them. Its not that noisy but just to make sure.
Possibly but unlikely. If you had a full 5 inch straight through off the dump pipe with no cat or resonator and it was below the volume limit, you would pass. It doesnt matter on the equipemtn for that kind of test, rather the volume of your exhaust. So you can try with your current stuff on, however you are looking at roughly $40 per test.
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
    • It's TWO steering wheels actually. 😛 one for each hand They are wheels, and they steer!
