Hey all, i need to clear an EPA notice in the next couple of weeks and my car is pretty much stock (R33 GT-R) except for a 3.5" turbo back exhaust. I've been told by Daalder in Dandenong (who do EPA noise testing too) that there's no way it'll pass cos even the stock exhaust barely passes in most cases.
Anyone got any ideas where to source a stock exhaust system? I've tried calling RE Customs and Racepace and a couple of local Jap/Import wreckers, I should hear back from them by tomorrow morning, but is anyone on here able to help, maybe you have one?
turbo timers have no use, my friends don't have 'em etc etc etc....
incorrect ash... with a turbo timer, you can put the windows up AFTER you have taken your keys out and realise the windows are still down... true story...
:O
  • 3 weeks later...
Hey lads, ive done a search havent found much on what im looking for; which happens to be for an engineer who can gimme a certificate on an intercooler hole, which is now welded up! ive gone to vic roads site n from there list rang a few but failed to find a suitable one! Was wondering if there was a recomendation or an engineer on here who can help me out!
Thanx
-Az
ahh shiet thats un luckly sounds like a pettit effort.. someone on here will know for sure.. i heard someone in bayswater but no idea.. try create a thread in vic cos searching will take ages
yep it was a pettit effort indeed! Yer checked the vic roads site that list most of the guys i rang couldnt do it ...whether be airbag or dont do coupes..was wondering if there was an engineer SAU usually goes to when in trouble, Non the less thanx lads i shall keep looking!
thankz
-Az
thankz
-Az
Oh airbag... good luck mate, i don't know anyone that will signoff on that.
you'll have to ring everyone on that list
Yer airbag is abit of a problem! Can u just remove the airbag? Non THe less i shall keep trying! @ alr33x yer mate...look @ the delema im in! go turnflow n u wont have to spend ure life looking for an engineer!
thanx guys
-Az
I'm curious to know if the EPA inspectors will pick up different low mount turbos on a gtr. Say garrett -7s or -5s or similar hks. I know your not suppose to have them but it's kinda hard to tell. If they are able to pick them, would they be likely to give u a hard time if u changed them back to stock but used r34 gtr turbos on a r33 gtr? I can get r34 turbos off mate if I'm likely to have to change the turbos over. Thanks.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
