Hey all, i need to clear an EPA notice in the next couple of weeks and my car is pretty much stock (R33 GT-R) except for a 3.5" turbo back exhaust. I've been told by Daalder in Dandenong (who do EPA noise testing too) that there's no way it'll pass cos even the stock exhaust barely passes in most cases.
Anyone got any ideas where to source a stock exhaust system? I've tried calling RE Customs and Racepace and a couple of local Jap/Import wreckers, I should hear back from them by tomorrow morning, but is anyone on here able to help, maybe you have one?
turbo timers have no use, my friends don't have 'em etc etc etc....
incorrect ash... with a turbo timer, you can put the windows up AFTER you have taken your keys out and realise the windows are still down... true story...
:O
  • 3 weeks later...
Hey lads, ive done a search havent found much on what im looking for; which happens to be for an engineer who can gimme a certificate on an intercooler hole, which is now welded up! ive gone to vic roads site n from there list rang a few but failed to find a suitable one! Was wondering if there was a recomendation or an engineer on here who can help me out!
Thanx
-Az
ahh shiet thats un luckly sounds like a pettit effort.. someone on here will know for sure.. i heard someone in bayswater but no idea.. try create a thread in vic cos searching will take ages
yep it was a pettit effort indeed! Yer checked the vic roads site that list most of the guys i rang couldnt do it ...whether be airbag or dont do coupes..was wondering if there was an engineer SAU usually goes to when in trouble, Non the less thanx lads i shall keep looking!
thankz
-Az
thankz
-Az
Oh airbag... good luck mate, i don't know anyone that will signoff on that.
you'll have to ring everyone on that list
Yer airbag is abit of a problem! Can u just remove the airbag? Non THe less i shall keep trying! @ alr33x yer mate...look @ the delema im in! go turnflow n u wont have to spend ure life looking for an engineer!
thanx guys
-Az
I'm curious to know if the EPA inspectors will pick up different low mount turbos on a gtr. Say garrett -7s or -5s or similar hks. I know your not suppose to have them but it's kinda hard to tell. If they are able to pick them, would they be likely to give u a hard time if u changed them back to stock but used r34 gtr turbos on a r33 gtr? I can get r34 turbos off mate if I'm likely to have to change the turbos over. Thanks.
    • @GTSBoy Ok so that was the shops problem...they showed R33 rotors on R34 page and i did not know 296 do not fit(and are for R33) Yes i bought "kit" with rotors and pads. Pads are ok(i have GTT calipers front and rear). They have some 324mm but no 310mm. So i dont know if they would fit. I have 17inch LMGT4s So another question. Can i fit those in the rear or they are just "too" big for that?
    • I started removing the tank a while back with the intent to give it a proper clean. Got to a bolt that I couldn't undo completely due to a diff being in the way, so just said f**k it and siphoned the gluggy old fuel out and called it a day. Looking it the tank it looks less corroded than the one in the pics for that billet hanger from Frenchy's anyway. Isn't it the fuel filters job to worry about this stuff? I scraped off most the crusty shit of the hanger but will give it another go before reinstall coz maybe the fuel and return pipes are also full of gunk
    • Pretty sure it is a common fault. I believe this is the only part you need, but don't quote me as I don't have a V36.  I also believe it is a bit of a pain to change and the device needs to be encoded to the car once it is replaced, so may need someone with the right tools. Buy Genuine Nissan 48700JF00D (48700-JF00D) Lock Set-Steering. Prices, fast shipping, photos, weight - Amayama
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
