I have run an external gate for a while now and im happy with the boost curve , no falling off at high rpm. And also happy with the fact that the car makes good enough hp.
At the moment i have the gate to atmosphere. Which hasnt been a problem as i drive like an old lady and never load or boost the engine on the street. So in my case its hear no evil, ppl dont look for evil.
I have been warned though that this year i may be getting pinged at track days as the EPA are enforcing db requirements at the track. Now i dont care about losing the cool noise at WOT, my concern is will the increased gas flow in the exhaust cause back pressure problems...loss of power/boost problems etc?
Anyone had a plumbed back vs atmo experience on the same car, setup and tune? I know of two cars that lost power when they were plumbed back. Is that the norm?
I am running a high flow cat and HKS Hyper exhaust, which has two mufflers. Will it handle all those by-passed gases?
  • Replies 52
Plumbed mine back... and the car sucked the wang.
I pulled the pipe out the next day :happy:
If your exhaust does not flow enough, you will have an issue.
If it does flow enough, then plumbing it back wont be a problem
I only had a 3" exhaust, not enough for 300rwkw
Was considering running a bike muffler off a TLR etc but its just more weight and agro that needs to be supported under the car...and also weight hanging off th tubular manifold . At the moment the weight of the wastegate is enough of a worry on the manifold...let alone throwing an exhaust system on it.
sounds fair
if i remember correctly i think it was SK that runs a support for the exhaust from the back of the motor
personally i will be setting up a support to run from either the block or the engine mount to load up the manifold so it ill not sink when red hot
any thoughts on running a seperate Cat and muffler on the WG pipe by itself ?
Ash, what were the effects of changing it to plumb back ??
Drive a stock turbo skyline.
Then put ane exhaust onto it.
Exactly the same, its the easiest way to describe it.
More power everywhere, better response etc etc
What brand of exhaust Nismoid?
Like i said, im hoping the HKS Hyper would be ok?!?!?!? It is a pretty quiet exhaust
Some Jap one :happy:
Needed a 3.5" at a minimum
i pliumbed mine back. and havent looked back. now i can actually here my motor and the all nice whissel from the 04 :happy:
11.3@122 with a bog stock bottom end seems to be enough proof for me that theres no power loss.
don't do it troy. it's like clipping the claws on a bird, or milking the fangs on a spider. it lets people know that despite being devestatingly handsome, you also have some nuts!
I say worry about getting pinged for noise if and when it happens. :huh:
I pulled the pipe out the next day :huh:
Now i dont doubt you know what your talking about... BUT
10.5 400rwkw+ plumb back screamer , 90mm exhaust with a centre muffler
...... ??? I pulled 300rwkw with my 3" plumbed back.. maybe this rule does not go for RB30DET's :angry:
Not saying it wont make the power, i did :huh:
The 3" system i had on my car, definately was a problem as the gate had to stay external
Then, my exhaust goes up and over the diff, where most R33's seem to be pretty straight and go under it.
Seen a couple of cars go from 3" to 3.5" and pickup some excellent results.
Nothing beats a flowing exhaust.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
