Okay guys. So I cant afford to spend another $4-5k on my big brake kit after spending a little over $25K on my build. But I need to be able to stop.
I know that they make an upgraded rotor and pad that uses the standard GTR caliper and such, I just dont know any info about it. If someone could give me some info about upgraded rotors and pads for the GTR33 that uses the stock caliper I would greatly appreciate it. Thanks a lot guys.
-Sayajin
https://www.sau.com.au/forums/topic/156455-upgraded-rotors-and-pads-on-gtr33/
what kind of power do you have and what do you use the car for?
DBA make slotted rotors for the stock brakes. DBA4000 or DBA5000 2 peice.... as for pads, if its a street car, DS2500 aren't bad, or track DS3000....
RDA also make slotted rotors for stock brakes, but i've only used DBA.
I'm upgrading the brake on my R33 GTR presently. From what I have found, and thanks to lots of advice from many on here, there are a few things you want to look at:
1) Rotors - DBA's are used by many and if the regular track guys like them (they seem to) I consder that a strong endorsement. Prices run around $500 a pair for the 4000 slotted. You can pick up some Japanese rotors but because of weight (shipping) you'll pay up.
2) Pads - Plenty of discussion on pads. Ferodo 2500's do seem to have a lot of fans. I'm giving Nismo S Tune pads a go. Pads will cost around $250 -350 depending on which flavor
3) Braided Lines - Pretty easy upgrade performance wise and another $250-350. Look nice as well.
4) Master Cylinder Stopper - See a lot of Cusco stoppers but UAS also makes one. $100-150 or so.
5) Air channels/vents - If you are going to be on a track they add a lot in terms of cooling. Nismo just discountinued theirs. UAS is talking about offering one. Not sure what they will run price wise but the Nismo one was sub $200.
Do the maths and this approach will cost $2,000-2,500. Next step up are various brake upgrade kits which I haven't looked into. They will get you 4 / 6 piston calipers along with larger discs. I'd take a look at the UAS website. Think Just Jap may also have a group buy to check out.
My car has Brembos so I'm happy with those and don't feel the need for the bigger step up.
Hummm... anyone ever heard of G4 Racing Kit?
I was looking on justjap.com and they seem to use the kit.
It is an EIGHT piston caliper kit for about $2200.... you cant beat the price for 8 pistons.... anyone heard anything about them?
http://www.justjap.com/g4brakekitinfo.htm
-Sayajin
ap or brembo or alcon kits.
well worth it. and wont crack in half at the track and wont eat threw pads quick either
Ignoring the kits (that cost thousands of dollars) and the fact that he wants to retain the stock brembo calipers, what ROTORS would you suggest if not DBA ?
In looking around both Endless and Project Mu have rotors that I considered. They were priced at a premium to DBA. At the higher end, Nismo rotors (front only) are $550 each. You will notice that most of the aftermarket parts companies make thier 2nd tier (above entry level) rotor for front only for GTRs.
TO4GTR - I take it you have a bad experience with DBA's? What happened?
The only rotors ive ever seen cracked at trackdays have been DBA's.
While this has been true for the 4000 series rotors with the stupid 'wiper' slot design, I am yet to hear of a 5000 2-piece rotor crack after track use.
I've had a couple of sets of DBA4000's, neither cracked.. just wore out.... I'm now trying DBA5000's...
And yes i forgot about the braided lines and master cyl stopper...
Air deflectors are next on my list to look at...
and Sayajin, just because they have 8 pistons doesn't mean they are better than a 4 or 6 piston caliper. I haven't used them, but i think i'd prefer to pay a bit extra for an Alcon kit or something....
Ferni,
Did you have any joy getting information out of PWR about the Alcon calipers? I wanted to know the piston sizes etc for their 4 pot gear & couldn't get an answer. Their website has SFA also.
Ferni,
Naaa, I was looking at the kit from UAS, but decided to try to make stock brakes work for now.... perhaps UAS can help you out?
I bet they were crossed drilled.Slotted ones are the best choice.Gave mine a hiding on my old car,no signs of failure even with harsh pads.
I've seen atleast 3 sets of DBA4000 slotted rotors cracked, the most recently was at Wakefield Park on a 300zx which was cracked almost entirely through the hub.
Edited by benm
I never had a problem with my last set of DBA 4000 rotors. They were 324mm and they lasted over 5 years. They were still fine but i replaced them at 30mm thickness while i had the cash.
I am now happily using another set of DBA 4000s on the front. I understand others have had problems....but i dont think any ppl in Voc have been having trouble with their 4000s or 5000s. None.
Perhaps those that have cracked are a function of not being warmed up or cooled down properly.
Anywya, if not DBA i personally wouldnt use RDA for anything but street application, in which case DBA will definitely be fine.
Of the others i have seen Project U look like a nice enough rotor. What is the problem with just using replacement Brembo rotors...and if need be have your local brake place slot them
DBA say if you don't bed the rotors in correctly they have a chance of cracking. Ie if you bed in new pads (big hard stops) with brand new rotors, then they may crack... so you should always bed in new rotors with very light driving to get a few heat cycles through first.
Having said this, i bet now my DBAs crack next time i'm out there :/
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
