What started off as a small drama grew to a major problem yesterday......... :/
I blew a small hose at the back of the head that goes to the turbo..A bitch to get to
buy i fixed it ..all good till i took it for a test drive..the temp kept getting higher i pulled in to a servo around the corner from my place and it was boiling its ass off.. not just boiling water but a nice thick
light brown thick oil based gunk..i knew this was not good i waited a a bit and tried to add some water and it was just blowing back out..after a hour a managed go get some water in and i tried to get her home got to the drive way and blew top radiator hose to bits..Head gasket..i hate that..
Great ocean road coming up
The G.P
So on the phone to RE customs and she goes in tomorrow
And i will find out how bad she is :(
So i will get a lift with a mate for tomorrow nights A.G.M
https://www.sau.com.au/forums/topic/156966-rchoo-the-car-dies/
arrr nooooooooo :(
Sorry to hear Wayne,
Mate all i can say is you are lucky your car will be in good hands... Ray is tops he will hook you up and sort you our asap...
Hope it's not too much of a costly repair.. Maybe a few extra goodies while u are at it ?????
perfect time to add cams i must say :P
as the head would be ripped off, machined, perhaps fully rebuilt
such an ass of a job, if RE get their ass into gear its not a lengthy process, all depends if the heads warped etc ... stupid machinests !!!
bad luck wayne... hope she's all hunky dory soon
if u have blown a big hole in the gasket keep it as a momento, i wish i kept the head gasket off my vl when i blew a hole about the size of a dollar coin in it ;)
replacement head gasket, machine the head (if it wasnt too over heated thats is), chemically flush the radiator, flush out the cooling system a few times an you'll be good to go again mate. I'd guess a workshop would be charging about $1500-$2000 to do this, depending on how dearthey are an how much money they wanna make out of it.
whilst the heads off, should add in there a new timing belt & pulleys as there shouldnt be any etra labour costs to fitting the belt as it had to be removed and replaced anyway (if there cheeky they'd add .2 to .3 of an hour for fitting the pulleys).
best of luck Wayne! Think she'll be back by the GOR cruise?
Sorry to hear Wayne, hope that RCHOO gets better soon. If ya get stuck for a lift to the AGM I'm not far from you, I can give you a lift. Again good luck.
Thanks for the offer mate ..but all under control
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
