Hey Chris you should start a new thread on the differnt applications you have figure it out that can be used in the V35 such as the TV, SAT NAV, etc etc . This one is getting really confusing it all over the shop.
will do. I just need to get admin approval.
I would be interested in that. I would like to do something with the screen etc. in the car especially since my car is now giving me the fcuk off (F0) error code! I am just not sure what is available, how much it will cost and the amount of work is involved.
I need a mule for sydney. I'm going to make a run down shortly. car needs to be done in carlton.
for more details on location and price PM me. it takes a FULL day to do properly.
you have pm
Edited by nismo 400 R N1
Hi Ben
I have been talking to a Russian company recently who is working on a conversion from Jap to English for the car computer. They wiil be able to conver all the screens to english that do not relate to the GPS function. The GPS is a whole other subject and one they may be able to help with in due course. The general menu/screen language fix should be possible withi the next couple of months. This may help you get rid of the FO error code as you should be able to read what it is saying.
Cheers
Andy
Hi Andy, I would be keen to get the menus translated - I have been watching the thread to see how you go with it. The problem with my CD player is someting different - the mechanism in the CD player is buggered - it can't play, change or eject CDs. It is apparently a fairly common problem with the V35's which is a pain because of it's integrated design. As a result I am interested in the full iPod integrations being discussed here, though I don't want to make my interior rattly by pulling it apart and back together again. However, if there was a good enough solution I could go to the effort.
I have read that the CD players sometimes randomly come back to life after a month or two, so I have my fingers crossed!
That is a problem they have warned me about. They have said 1 in 5 DVD players need to be removed and cleaned to get them working.
Hi chris,I have a digital box in my ute and have just bought an 03 v35.Does this mean i could reinstall it in the skyline to get the tv working?Also be interested in the language conversion Andy.And last of all did anyone have any luck with the stickers to translate the buttons into english.Cheers.Matt.
pretty much correct. you will need a patch lead to get into the V35 TV box. also the TV you have needs to spit out NTSC for it all to work properly.
I have a source for the CORRECT buttons though they are NOT cheap.
hi chris, are you referring to the actual buttons (as in replace the original) or stickers that will go over the jap ones?
thanks.
$POA. I have base prices for certain items but I really wish to keep them private. if you want to know - ask me. to do the whole lot is in the early 4 figure mark. the buttons- $190.
  • 2 years later...
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
