  • Replies 68
don't tell me any of you knuckle heads think this is for real? the old "i shipped my car to XXX but can't register it so want to send it back" story has been in action for a couple of years now.
just another scammer trying to get that cream. dolla dolla bill yo. next time I'm passing through budapest I'll be sure to look out for a midnight purple GTR.
The seller has revised the following item information:
Date Time Revised Information
21-Feb-07 19:11:59 AEDST See Description
Subtitle
Minimum Bid Price
Title
PictureURL: Pictures Added/Deleted
Details
Description
Gallery
Category
Private Designation
Reserve Price
Item Specifics: - Automobiles
Changed Type from Commercial Vehicle to Sedan
Changed Doors from 2 to 4
Changed Date of Manufacture from -- to 1999
Changed Colour from Brown to Purple
Changed Engine Number from -- to RB26DETT
Changed Kilometres from 32435 to 2185
Changed Manufacturer from Ford to Nissan
Changed Model from Falcon to Skyline
Changed Transmission from Automatic to Manual
Changed Engine Size from 534 litre to 2.6 litre
Hmmmmmmmmm?
:P cheers :D
I haven't received a response from my last email... I'm losing hope that I'll be able to buy such a 'bargain' :P
And he was so prompt in suggesting I pay the money while he ships the car back here for me to inspect. Oh well. Maybe I'll send another email requesting details of the shipping company he used to go from Adelaide to Budapest. :D
Edited by writeoff
damn never knew they made 4 doors for GTR's
lmao
they do have 4 doors GTR
see the thing I don't get is if I were to try a fraud, I'll at least get my stories straight do some background photo shop...and at least get a reasonable price so there are no suspicions...
I saw a R32 4 door GTR on one of the video's of some nissan car musiem posted on this forum....and yes it too was Autech.....R33 4 door ones come up in yahoo auctions here their...
all Autech build..
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
