does ur car have pod and fmic?
if it has 1 of these then its ok. a cold air box isnt creally considered a mod unless ur the cops. i got 1 and i went epa with it, they said it was cool. and coz it was a box (enclosed) and my pod was in there with fmic, that was ok too.
cops dont know shit, they just after bronie points!!
hope that helps
Intercoolers that are larger than standard or have a different mounting location or are added where none were originally fitted, are permitted only if no other changes to the intake system have been made.
In other words, you may have a pod filter or added/modified intercooler, but not both
Guidelines are clear as day.
If someone got passed, they were lucky.
Dont expect it to happen everyday
I was at the EPA the other week and the guy in front of me came in with a cooler and a pod that was it and he was sent away to come back with only one of the modifications.
Was speaking to the guy from epa who gave me a leaflet on what you can and cant do... EPA are genuine and follow the rules and guild lines fairly as they are set out this being one of them...
hmm this guy is going for a roadworthy, not trying to pass an EPA test!
ive been speaking to alot of people who are lisenced road worthy supplier mechanics, and they said thier guidelines for a roadworthy certificate are set by vicroads, not EPA, so i asked them the hypothetical of passing the car with a front mount and a pod filter... and they said, yes because those are not on the requirement list of the road worthy, as long as they are done properly and are safe (eg pod is bolted down) and front mount isnt leaking and is mounted properly, then they are fine!
EPA and vicroads should really get together, sit down and combine thier roadworthy/epa requirements because at the moment they really are two different entities that have thier own rules!
-Ruffels
Edited by Ruffels
Ur point?
Technically what i posted is 100% correct.
RWC, EPA test... whatever.
If your car does NOT pass EPA it is not roadworthy. Most engineers over look this when compling a car, but it does matter.
Ur point?
well my point is, the guy is worried if he will pass his roadworthy or not with his cai box, and from his sig pic it looks like he might have a front mounted intercooler too, and i am letting him know that it most likely will pass his rwc with the two induction mods.... he will fail an epa test, or if i police officer pulls him up on it he will have to change it, however i answered his question about passing his roadworthy... doesnt mean you have to have a stab at me for answering his question...
-Mark
Edited by Ruffels
ffs this gets covered like every day.
Its not legal, but will prob pass the RWC as the form is generic and basic form for all cars.
But, when they defect you and u need to go to the EPA...you will need ot remove it.
Period.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
