  • Replies 49
Chaser as well :D twin turbo 2.5L
hmmm wait a sec.. same engine as soarer.. are soarer's faster then r33's in stock form?
Same engine maybe, but the soarer is heavier... On power to weight it would go:
Chaser at 206kw in 1480kg-ish = 139kw/tonne
Skyline R33 at 185kw in 1360kg-ish = 136kw/tonne
Soarer at 206kw in 1560kg-ish = 132kw/tonne
Not that I'm suggesting that power to weight is the only factor that influences acceleration...
Hmmm.....Chaser for sure......
Does anyone Thought about the Tourqe from the TT motor should be significantly hight at Low reves than the R33...
Never really driven a chaser though... :D
Dunno about that - I've always thought the 1JZ twin turbo to be slightly laggy... Although that experience is from a 16 year old Supra. The late model single turbo VVTi 1JZGTE is meant to be far better down low.
chaser. if the skyline was manual it b close i think especially if you got a good launch (good tyres)...
Damn....i though a Manual R33 could keep up with it, given that the chaser is Auto, I know there good..but never though that good.
I have Owned Both a 1997 Series II R33 GTST and a 1997 Toyota JZX100 Chaser Auto.
The Auto Chasers Maul Manual and Auto skylines with up to 200 rwkw.
I had a Catback exhaust on the Chaser and a K&N Pod filter and with the auto ran a 13.2.
On the street, most of my mates 200 rwkw Skylines got dusted. They develop a shitload more torque than the RB25, even More than a Standard RB26.
Beautiful car - get a Manual one though, so so much better and they can pull 13s with no mods whatsoever.
Just to remind you - a JZX90 - Pre 96 Model with the Old 1JZ would be on Par with an Auto R33 - after basic mods though would eat a 33.
JZX100s Came with a Different Motor alltogether - Single Turbo 1JZ VVTi.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
