Hey guys,
My brother also owns an R32 gtst & when his engine is cold (left overnight) it hesitates on acceleration. If you keep the same peddle pressure it will hold back for a second then eratically rev harder as normal. Is this a normal thing? or maybe an issue? Having said that it operates fine once the car is at normal operating temp.
Thanks guys
https://www.sau.com.au/forums/topic/158452-r32-gtst-hesitates-when-cold/
http://www.skylinesaustralia.com/forums/in...hesitating+cold
the problem is in the ECU.
it is nissans way of warming up the engine with minimal stress on the engine. it goes into rich and retarded mapping up until something like 3300rpm or until you put your foot down a bit more.
do it next time you drive it cold, keep your foot at the same level and get to around 3300 and you will notice a sudden rush as the fuel and ignition maps have gone back to normal.
it is completely normal
That doesn't sound right. The manual advises to drive easily when cold, till temps are normal, so why would they make the engine run shit at low rpm, doesn't make sense. :rofl:
When warming up all tunes run rich with retarded timing, but apart from a lack of power, this should not effect drivability.
That doesn't sound right. The manual advises to drive easily when cold, till temps are normal, so why would they make the engine run shit at low rpm, doesn't make sense. :)
The above is just a quote from the link i provided.
I am not sure whether this is normal or not, although most r32's seem to have this problem. Would like to know the answer to this problem :D
its a common issue
i personally think its got something to do with the oxygen sensor needing to be warm/hot to operate
it seems like when its off boost it has no power at all, but when it comes into any boost at all it jumps into life like it normally would
neither do i.
check your fuel lines nisskid and make sure they arnt perished through and leaking
yeh i figured it would probably be a leak in the line, weird thing is, it only smells when its cold and running, so unless for some reason the leaks would close up when its warm, doesnt really make sense.
do u 2 have straight through exhuasts, cats?
Only have catback exhaust.
Uploaded a video of my daily cold start. Anyone have similar?
As you can see/hear, the key is turned for a while, then it jumps to life and falls back to zero. a blip on the throttle brings it back to life and idles normally...
Cheers
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
