my birthdays comming up and i got a relative spending about 200 on me. so i defenitly wanna get something for the line. so far ive allready got front dump, boost controller, full exhaust, heavy duty clutch, and KnN filter. will also be getting a fmic in a couple of weeks. so my question is what should ii get next (as far as performance) for around that price range.???????
one option i was considering getting a tune on a dyno.
any other suggestions??
https://www.sau.com.au/forums/topic/159235-200-bones/
Why does everyone always think about power mods?
You can get just about ANY suspension component (within reason) for around the $200 mark.
Tie Rods, Rack Ends, Caster Arms, Camber Arms, Hicas Lock Bar etc.
Someone mentioned tyres, thats also not a bad option... for $200 your pretty limited, id be looking at something for your suspension. Grab them for your bday, set them aside, accumulate a few more parts, throw it all in one weekend and get yourself a wheel alignment.
EDIT:
Add some nice brake pads or a service to that list as other options also.
Edited by `nigno
https://www.sau.com.au/forums/topic/159235-200-bones/#findComment-2955895
cos this is SAU. that and there arnt any real good suspension mods u could get for that. caster, camber etc bushes all need a wheel alignment, so ur looking at another 100 or so ontop. for suspension its probs best to save up for all them at once so u can get the wheel alignment at the same time.
only thing really is maybe sway bars, or i should say; bar.
https://www.sau.com.au/forums/topic/159235-200-bones/#findComment-2957246
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
