2nd iz good, az nark said! Not as much slammage going on by the time you're going for third [+ I miss the darn thing half the time]. This may be my downfall at the drags will have to wait and see...is it just me or does your cars gearbox get tighter when you are driving hard? I find third gear needs to forced a bit - but only at high load / revs? hmmm
3rd has the best range though from 25 / 30 all the way up to 150+ in mine :P [on the track that is].
oh yeah i like corn chips :)
yeah when i drive hard, 5 gear crunches in
otherwise normally it just slots in
and yeah 3rd is a bitch to get in when flooring it
i always get huge gear crunch when i take off at the lights
very embarrasing
not that i speed or anything....
well i like 5th gear the most, COS THAT'S THE F*CKEN ONE I'M IN THE MOST!!!! (5th @ 60 so the car isn't too stressed) :)
EDIT: i find that 2nd does not like to change smoothly after reving 1st a bit. But going to 3rd and 4th i can change real quick.
But then again i have a TOTALLY different car to u guys.
Let's just say it's shy of a few litres and turbos :P
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
