Hey guys.
Now as much as i love driving my 33, i've come to realise i drive it too much and want to look after it as much as i can.
And so i have decided on buying myself a 2nd car. I'm obviously looking for something reliable and cheap to run. I dont care about looks etc...
I know it depends on the previous owners and how well it has been looked after but im just after a general idea.
I have heard that the old Corrolla is a reliable car as with the Ford Lasers and TX5's.
If any have you have a cheap old shitty run a round let me know of your experiences.
So any suggestions will be appreciated. Will hopefully be getting something before the weekend....
Cheers
Musky :)
  • Replies 61
Hey guys.
Cheers
Musky :rofl:
ford falcon
Hey guys.
Cheers
Musky :rofl:
get an excell sprint... its cheap.. runs on an oily rag.. and when theres a problem with it over 1000 bucks throw it away
even though its an hyundai.. it is a good run around car if you throw oil at it and dont race it.
3000-5000 clams will get you one with under 100,000kms on it.. who cares what it looks like.. just dont rice it up
Get a small motorcycle, if you just want it as a daily driver/rider it's damn cheap. And when it rains just take the car to work.
I personally do the opposite.
Have a car for daily duties and a bike for fun.
But they are damn cheap to register, and run, well little bikes are. My 750 is quite expensive when it comes to tyres etc.
AE92 Corolla twin cam, with the 4age motor
even an AE82 twin cam corolla
will last forever.
Deffinately :wub: !!!, I have heard from countless people about the bullet proof reliability of these things, some are a little expensive for their age on carsales, but look after them and they will go forever!!
To me for around the $3 - $5k mark you cannot go past this car!
r31 skyline mate
from an auto executive model, up to the silhouette range, GREAT runabouts
and surprisingly fuel efficient even though they are 3ltr straight 6
silhouette models are LSD (most worn out) and trip computers etc
BEST seating position out of many cars that i have sat in, also quite good if you;re a tall or big bloke
the wagons are good for throwing a lot of shit in the back.
19 15" rims to be precise
if you're after a reeeeeally nice 31 runabout, this is the series 3 ti model
trip computer, auto, full electronic options and plus interior
top car
above all, the ladies love em
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
