  • Replies 194
I'm in.
I'll see you there Ash. :)
good to see cubes...
just trying to work out the numbers of who's coming.
so i have added a list to my first post.
everyone have a look and let me know if you or freinds want to be added etc
at a guess we are heading towards 30 rb's..
that will be a sight to remember..
Edited by dangerman4
So you guys from up here ( clean-gtst, grim and anyone else up here ) Do you want to cruise in together and back? We will be doing the hard yards so we may aswell do it together!
yeah lee sounds good, meet up down this end of town then meet the guy's at mile end then down south. if it's a 250km drive from there it's gonna be over 300 for us. But anything to see a massive line of line's cruisin on the open road and especially for a good cause :D
Id be keen to meet up and cruise down together, just need to work out some times and where to meet and ill be there!
Im there. Meet points like 2 minutes from my house so im in. :rofl:
Will it be dark by the time the cruise is over, might have to get my headlight wiring fixed, push the brake pedal and the headlight and dash lights light up LOL
For those everywhere not near the official meeting point.........ive noticed that the etsa car park is still available to get to
Meet at ETSA car park 11 sharp, gives us like an hour to wait, meet and great and then cruise together to the official spot further away
what do u guys/gals think?
Is the 250 odd kms we're covering just one way?
no its approx 250 kays total.
it may be closer to 300 kays for you guys out the other side of the city,
but that will depend on your final route home.
for less then a tank of fuel it will certainly be one to remember.
as far as time frame goes i would assume we should be finished by around 5 o'clock
any other questions let me know
cheers
Darren
Yeah I'm keen to meet up and cruise down south to the next meet point. Should be a good cruise :)
Just got an email from my Photographer buddy. HE'S IN!! Should be able to get some awesome pics.
Edited by CleanGTS-t
What's weather like? I'd like to go but my drivers side window is stuck in the downright position and this could pose a problem if it starts pelting or even spitting with rain. I'd like to say I'm in depending on weather.
Yeah I'm keen to meet up and cruise down south to the next meet point. Should be a good cruise :(
If we have to be at etsa park around 11 and at the final meet point at 1, then im thinkn us guys out north should aim to meet say at Munno Para Maccas at say around 10am? What do you think dave and lee and anyone else down our way?
We are going to a christining at 1pm. However, we would like to meet up, if I may have a PM of the organisers to call after we are finished to meet up that would be great. Thanks, BB
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
