hi guys it has cum time to go big on the brakes. i have a 540awhp r33 gtr soon to be 600awhp and want to upgrade my brakes. have looked at just japs big wp brakes and nengun for the big trust grex systems both 6piston front and 4 rear with 355 front disk and 330 rear(not interested in the g4 brakes) will cost around the 6-7 mark installed does any 1 have big brakes that there recommend ap or endless or alcon just want the best brakes to pull me up when i need to stop... any info would be great
https://www.sau.com.au/forums/topic/159624-big-brake-upgrade-for-gtr/
  • Replies 75
Posted Images
I assume you are aware that you will not be able to use your current (standard) brake master cylinder in conjunction with any decent brake upgrade. The hydraulic ratios will be wrong, in addition to the leverage and movement ratios of the pedal and consequently you will most likely end up with one or more of the following;
1. A long brake pedal (excessive motion)
2. A heavy brake pedal (excessive force required)
3. An imbalance in the front to rear braking distribution (premature front or rear brake lock up)
I see so many cars that have had extensive/expensive calliper and rotor upgrades, that stop worse than standard. Adds up to a big waste of money, for no benefit.
:( cheers :O
:D cheers :D
Very informative post...but...whats the point of it if you don't tell him how to overcome the issues you have addressed. Id like to know as well.
I thought the answer was obvious, get the right sized master cylinders as recommended by the calliper manufacturer. I say "cylinders" (plural) because it is most unlikely that you will find a tandem master cylinder that will properly match any decent calliper upgrades.
:D cheers :D
I have found ppl tend to make a simple topic more complex then it needs to be.
Sure, run out and spend lots of money on bog front and rear kits...but all you need is therma capacity. Std gear works pretty well, but has its limits. The great gear works better then the good gear which works better then the std gear. But i dont think the difference in actuall performance is all that dramatic. The feel yes, but performance no.
. SO you have std Brembo rears, then make sure the rotors are healthy and lines and pads ok. If you have 17" rims grab some 343/355x36mm rotors and run them with CP5555 AP Calipers. If you have 18" wheels then look at running 365x36mm rotors.
Relatively cheap upgrade and works well with std rear calipers/rotors. Just need to play with the rear pad to suit the front pad you are running.
Its all the thermal capacity you will need from a street/track car. Unless you are doing more then 10laps at a time and its actual racing where you cant afford to back off for a single lap to help temps get back under control before running off into the sunset :D
Putting a pedal box in a road car is massive overkill in my eyes...cool, yes. But just be prepared to spend double on what you spent on the setup paying someone to dial it all in and getting it to work as well as the std setup....development costs money. If we are talking about a race car then save your money and strip weight out of the car. It will be cheaper, help smaller brakes live and will actually decrease stopping distances. :D
good post Roy, have you been able to obtain well made caliper offset brackets.
Gary...You answered my question by elaborating in your next post...thank you. Now here's two more...what is the ideal hydraulic ratio? how is it calculated?
The porsche upgrade seems to be a good one , they are monoblock calipers ! john at uas sells them as a upgrade for gtr .
For offsetting what caliper and rotor? There was someone floating around late last year doing them. A few ppl bought some, though i have not heard how they have gne with them.
I have had moine on/off so much of late...it is a budget fix that works well. But the more i look at it them the more i am tempted to just bite the bullet and get 4 pot APs on 330-324mm rotors. They are hard to go past for value and performance. But there is always the offset brackets for the cheaper option again. Someone is about to trial some R32 GTR calipers on 340mm rotors. I was going to do it, but honestly im sick of wasting money trilaling stuff because im curious...my car is still slow. Any money i spend from now on has to make my car go quicker :D
good point. brakes only slow you down.
the porsche 6 spots are a good price at about 800 per side, but you need to add lines, discs, pads and caliper mounting brackets
danoz, not sure why you don't like the g4s, what problem did you have when you tried them?
also....are you having brake problems already or do you think the extra 60kw is going to kill your current ones.
I've got the Porsche 6 pots on my car, i'm very happy with them. But I do need a bigger master cylinder, I'm hoping the R33 one will boost it enough so the pedel isn't so long after some knock off.
come on guys brake manufactures dont make brake for gtrs that need all these master cylinders to be upgraded or there would sell the master cyliders aswell alot of guys running big brakes say its a mazing difference or there would go spend 7grand on a set up i rang greedy today there run there big brake kits on there gtrs all day on the street and the track for years with no problems at all.
tracker... i just dont like the look and the length that g4 have been in the game i no people using them say there look fine but time will tell. there are propbly a good thing i just want quillty proven race parts
I've got a question, I've got brembo f50's on the front and standard rears on a 90 model 32 ..
i'm in need to get new rotors. they are a two peice hat design and have shown signs of hairline cracks. now i'd say they are fine for the street.
but i want to go to the track on april!
where can i get rotors in sydney for them? what other info will i have to provide to help you guys with my search?
Cheers
this may seem like a dumb question, but how and where did you ring Greddy? I have spoken to a few of their guys in japan, but the only ones that could speak english were mostly just sales people, all the guys with the technical knowledge speak japanese only (unless you speak japanese?).
my workshop that looks after my cars deal directly with japan. the question was ask and anwsered the sales guy went and asked the techs
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
