Hello how is everyone?
I Bought this car around 6 months ago and i love it.
its a Purvis Eureka kit car made of fibreglass and is mounted on a VW chassis.i bet no one on the road would think this is a 4 cylinder 45kw car :P.
Engine:VW 1600cc
Weight:600kg
Wheels:14" bathurst globe
Height(from ground to roof):1m
Tell me what you all think and What licence plates would be good for this car :happy:
https://www.sau.com.au/forums/topic/160922-who-like-my-new-car/
they are nice kit cars - looks like it needs a bit of work - but once its looking mint, expect lots of heads turning.
MR2 engine will def go in nicely....rb25/26 would be better if it can fit and if u can put all the right parts in it - hell, you probalby dont even need a det or dett...just put a de - with 140 odd kws and 600kg it will fly! :P
edit: any interior pics?
Edited by emsta2003
Yes i have one interior pic but its with the seats removed and doesnt look that good but i will put it up.I was thinking of going rotary for this car but theres so much work involved so maybe down the line.Yes it does need a lot of restoration but then again i only paid $2500 for it :happy:
if its got a beetle motor a wrx engine or an EJ25 will be piss easy to install!
these are cool. use to be one in my area when i was young
I cant drive turbocharged car mate :P P plate restrictions.
Read an old magazine article on these years ago. Apparently the hydraulics failed in one of them and someone was stuck inside the car until they could do something about it. I can't remember the exact circumstances and what happened, but it sort of turned me off them.
Get an EJ20 or EJ25 non turbo then, they're a relatively simple engine to turbo later on if you wish, but even in non turbo form if you trick it up with an exhaust and intake it should have more than ample power to make that thing a ball tearer.
Edited by d0p3y
there are a few of them in town.
as for motor, you would need to see if the car has a engine size rating (the biggest motor you can put in that car). this would depend on state, etc.
yeh i think its 1.8L turbo or 2.5L N/A.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
