that GTR came 1.5seconds from the track record set by derik pingle in his Lola F1. pretty damn good to stay that close to the Lola!!! it was awsome to watch tho, he was with a small team of skylines at the gatton sprints wasnt he???
CJ
there was an outfit there with 2 or 3 lines, One of them was a 33 with a smallblock shoehorned in. The giant car was independant of these guys tho. They didnt appear at qr on the weekend either. A huge disapointment to me as I really wanted to watch that car for more than one corner a la gatton. No matter, theres always next time.
  • Replies 98
Well from my last few enquires:
Stoptech 332*32 hatted rotors + ST40 calipers + braided lines + pads = $2280US approx $2850 Aust. Delivered. Note this is ex US, I haven't got a price from the local distributor as they need to email the States.
Alcon 335*28 hatted rotor + 4 pot caliper + lines + pads+fluid + $3808+gst+freight ex PWR direct.
AP Racing CP5200 + 330x32 hatted rotors + lines & pads = $3200 + freight. EX Racebrakes (pick one)
The endless stuff (6 pot on R33 hatted 324 rotors) is listed as Y436,590 plus freight. Ex Greenline.
So they appear to be reasonably priced to me.
Oh, and Roy, I have delicate little feet. Like a ballerina.
Apparently the new distributor for Stoptech gear is now V-Sport. Tony who I spoke to was very helpfull & knowledgeable.
Also, from what I understand there is a Brembo kit for a Z32 with a 332x32 rotor & an F40 caliper. Has anyone used these?
LOL..you seemed like you were a bit disappointed at dinner with your times up until the last session. I was stoked to see you held your breath for the last session and sucked out a great PB :)
By my timer i did the 1:52.04. So they gave me 0.04sec on my quickest lap. I would have lved if they gave me 0.05sec. 1:51.999 sounds a lot faster.
They are very beautiful. Can I ask who you bought them from?
Got them thru Perth Brake Parts in Kewdale
It was a toss up between these and a set of AP Racing, personally I preferred the AP Racing Calipers / Disks, but went for the Brembos on account of percieved originality......
djr81 i finally checked our rotors and they are 343mm X 32mm fronts....backs are same dia but thinner...didnt check width sorry.
Thanks man, I sort of suspected they might have been. The 343mm size is about all you can stuff under a 17" rim. Even then it works out to be 13.5" diameter. Which leaves a nominal 1.75" on each side. I say nominal because there isn't anything like that amount of room.
actually i checked the rears again...with a measuring device other then my eyes....backs are 323 X 1"(bout 25.4mm)
I measured fronts when we just put new rotors on, and i eyed them off with the backs and they looked similiar, well 20mm smaller in diameter they actually are.
Recap Fronts= 343mm X 32mm
Backs= 323mm X 25.4mm
Alcon monoblock 4pistons front and rear.
Run SBS Dual carbons up front and Carbon Ceramics on the arse.
My apologies for the fark around with the half arsed info.
Edited by r33_racer
Wakefield Park 14/15 April 2007, Improved Production Over 2 litres, pole position, fastest lap (1.063383) and 3 wins from 3 races. Less than 2/10ths off the lap record set in 2002 ie; before control tyres.
Doesn't seem to me to be past it's use by date.
:D cheers :thumbsup:
PS; well done to Dave and the BSM boys, all that hard work paid off.
nice one dave! mmm he is such a good pilot. nice to see them back on top. and a new paint scheme too... congratulations.
are they still running in CT too?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
