im pretty sure the wiring mod from GTR to GTST is the same on all of them. only difference is you'll need some sort of resistor or something (sorry for being so vague) to convert the 5v feed for the igniter to 12v.
read through the pages and you'll come up with your answers.
  • Replies 765
Thanks guys,
not sure I'm up to installing it myself... have heard a few professional have had problems if they don't know what they are doing (or new to the e-manager).
does anyone know any tuners in Bris / Gold Coast that work with them?
i got my emanage blue tuned my pro torque, pete knows the emanage back to front and has tuned a fair few of them. give him a call on 0438 876 649 he is at springwood
Hi security. :P
Yes i have read all of this thread pretty much thats why i bought the emu.
I have set jumper 8 to 12V as instructed and installed the other crossover/ internal plugin for 34 gtt.
I just need a deffinate answer on the gtr harness compatibility into r34 gtt.
I have the universal harness already but would rather it was easily removable.
Thanks again. ;)
100% does not come clos to fitting. R34 GTT will not ever have a plug and play harness i have been informed. :nyaanyaa: maybe buy a field harness instead.
Wheres Trent gone ??
He must be busy
hasnt responded to any of my emails for ages
sorry yeah have not been in for weeks.... flat out with work day time and AH. my work email has a new filter so i figure that is why i havent recieved any of your emails. sorry.
cheers trent
damn it :whistling: .
Thanks for confirming that. i suppose the only option is the wire in harness.
going to be difficult to remove if i ever wanted to.
the way the wire-in is designed is that if you ever wanted to remove it you could take the emu wiring out and plug the previous wiring back into each other. the emu comes with some 'clip-lock' crimpy things. just pay attention to the way it goes on and it will be easy to reverse.
get someone to order you in one. i doubt many shops will keep it in stock.
taa mate hoping someone might know if anyone has stock...slide will have stock around about the 16th sept
anyone know where i can get a N4 plug n play harness....no ones got stock
TRUST japan was out of stock, soon all our back orders will be filled and we will have 100 on their merry way.
TRENT:
Ive got a 200sx with the ca18det , and having problems with ignition misfire , have tracked it down to 3 volt on the AFM but it dosent happends all the time , i have a Pressure Sensor from greddy and followed your guide but the car runs like crap with it :blink: whats wrong :)
And wich map trees do i need to remap , only did Temp map for the engine idle because ive tossed the a.c.c valce to hell... got a plenum from custom plenums here in australia instead... And also Injector map ... noticed that it hase a idle map indeed and accelerator map and so on... what does they do :D
And also do you know what lagtime it is on pink Nismo 555cc injector (topfeed) for the CA18DET , bought them from Greenline but havent got a reply for my answer in month , know i use stock 0,6ms on the nismo aswell...
Also is there better to use 300zx MAF or Pressure Sensor , im not going to get over 400 horsepower.... should i sell my pressure sensor and go with the maf ?!
Can´t go to you guys because i live in Sweden so a couple of guidlines or hints would be great... Have started a thread on EmanageForums but didn´t get my problem solved... when the engine stalls it help to clutch and rev and it dissapears... and it dosent happend every time... have tried new sparkplugs , coilpacks and so on... Buddy of mine hade the same problem so he bypassed the coils and it dissapeard , we did then the same on mine but fault still remains...
Link to emanagethread :
http://www.emanageforums.com/forums/showthread.php?t=901
Please someone help !
Hi all, Justa quick question what are the benifits of having the ignition harness? and the injector harness? what do they do?
I will be running aftermarket injectors nismo 480cc on my r34 gt-t. do i need the injector harness?
Thanks guys :laugh:
Thanks guys :)
ignition harness allows you to adjust the ignition (timing).
injector harness allows you to adjust the duty cycle of the injectors (fuel).
yes you will need the injector harness to take advantage of the bigger injectors.
and i'd recommend getting the ignition harness too. dont be stingy.
Trust have specific harnesses for most vehicle types. To avoid any damage when installing it is recommended to use the correct harrness for your vehicle. When using a harness there is no need for the optional injector or ignition harness.
I found that on nengun while invesigating pricing on additional harnesses. Now im really confused.
Anyone please clarify?
Hi me again, just thought id post what mods i have and are about to complete to give you guys an idea of where im heading.
My mods are
R34 GT-T
Hks front pipe and Hks dump into high flow cat and Trust PE 2.
Hks type S FMIC.
Hks Gtrs kit.
Tomei fuel pump.
Nismo panel air filter.
C's short shifter.
Greddy Profec 2 ebc.
Splitfire coil packs.
And these are soon to be installed.
Nismo 480cc injectors.
Nismo FPR.
Z32 airflow meter.
Emanage Ultimate + universal wiring harness. (jumper 8 set to 12v plus internal plug installed)
My goal is 250rwkw (streetable, daily, reliable power)
Ok hopefully that clears up why im asking questions about the injector harness and the emu in general.
Thanks guys.
what they mean by that is they have a harness you can buy with all the wires that you'll need already connected, so all you do is plug it in and off you go. they ONLY come with ALL the wires ready to go as its a single unit.
the separate harnesses are used if you're going to wire them in 1 by 1 or if the specific harness kits dont come to suit your car.
Hi security thanks for the response, my universal harness has 3 plugs at the ultimate end. ie theres no more room for any other plug into the unit. Surely this means that i have all the necissary wires to control the ignition and the injectors. if not where does it plug into?
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
