  • Replies 166
Posted Images
Al, how much did it cost ya to get that sprayed? i remember reading in that other thread you gotit done professionaly. ive got mine prepped and stuff but i want it in the same paint thats on the rest of te car. not confident enough to do that myself
Facia was sprayed when i resprayed my car.
nar im pretty sure the series 2 are painted to body colour with normal plastic underneath. If you're denfinate about doing this, do us a favour and scrape it back to find out. if not go and a get a Series 1 Garnish from a wrecker anyway :(
Edited by -R33GTS-
Got my series 1 sitting on the lounge next to me.... next weeks project!
And suddenly thought maybe the series 2 would possibly be clear underneath, and i wouldnt need to spray paint this series 1!
Will get a knife on it this weekend.
Did you get this new or second hand? How much did you pay for it?
Let me save you damaging a good facia.
The S2 is made from black moulded plastic, and can not be used ;)
Thanks mate ur a champ ;)
I hope mine turns out similar to yours, im thinking i might try a cathode and neon light...
I considered using neons but the facia is slightly curved and thought the neon wouldn't flex enough :laugh: . I could be wrong though.
My light can not be seen during the day, that's why i hooked it up to my parkers. You'll need a red filter to possibly see it during daylight hours, but this too may not work well.
Second hand, $35+postage. It's in awesome condition!
Oh. Bugger. At least i know without damaging it. Thanks
this will be probably too fiddly but is it possible to spray it from the inside? my car is black andim thinking if i could just block the light in the right places itd still look sorta clear from the outside but light up at night. another plus would be i wouldnt need a perfectly smooth finish on the paint. wat do you guys rekon? just a bit of a brainfart i had
I dare say it will not be possible to spray from the inside, as the lense has a dimpled texture on the inside.
What do you mean by 'dimpled texture'? ;) I can't see why this cannot be done.
Also, if done this way, you could possibly keep the chromed SKYLINE writing intact without having to scrub it off. Or will the LED not emit light throught this? (Are factory optioned illuminated series 1's SKYLINE writing still in chrome?)
having an irregular texture will make it hard to get the outline of the letters right from the inside. but thats the only issue i can see.
i dunno bout the paint on factory ones but there was a dude selling lightup garnishes on here. one was silver and looked like the letters were painted too. i have nfi how he did it but it still lit up well
edit: found the thread. http://www.skylinesaustralia.com/forums/in...howtopic=161444
That looks amazing!!! :happy: I need one of those bad.
  • 4 weeks later...
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
