Congrats to Steve Glenney who finished 2nd to Jim Richards in Targa Tasmania. He Was in a R33 GTR which i believe is prepared by Tillbrooks here in SA. A good effort as i dont think any one can really match Richards ability and equipment.
Quote From Targa website:
Porsche driver Jim Richards won the Targa Tasmania tarmac rally Modern Competition for the seventh time after turning back a strong challenge from South Australia's Steve Glenney in today's fifth and final leg.
Richards and Tasmanian navigator Barry Oliver won the 12th annual Targa event in a turbo Porsche 911 with the lowest penalty time of 22-mins 30-secs. They finished 1-min 10-secs clear of second-placed Glenney and his navigator Clayton Lang, also from South Australia, in a Nissan Skyline GTR.
https://www.sau.com.au/forums/topic/16224-gtr-2nd-in-targa-tas/
nice.. i heard of an R34 GTR N1 being specc'ed out for rallying that was from tassie.. not sure whether it was in this Targa .. but i think it might been in the next one.
Apaprently they got a top 10 finish last year in an EVO but they needed more power so they went the GTR.
i would say not even a porsche 911 turbo would be able to beat the combo of Richards and GTR
oh and gordy, that R34 GTR N1 was staying around my area in Hampton. Saw it down Hampton st a few times... then saw it parked outside a house, with like the names on the rear side windows and all the stickers. Look awesome!! too bad i didn't have a digi cam with me :) Up close tho, it looks friggen mean.
The stickers are different to the ones i saw in the pic above, but i doubt that the chances of there being 2 White, R34 GTR N1's with full rally spec cosmetics and mods in Oz. And i'm pretty sure had Jason White on the side window, but really can't remember.
I want to see Jim Richards in a R34 GTR N1 next time.. now that would be the coolest :)
Ok here we go
R33 genuine N1's
806Steve Glenney SA1995 Nissan Skyline GT-R V-Spec N1 what an absolute gun !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
914 Jeff Keyte, TAS 1998 Nissan Skyline GT-R V-Spec N1 Mines
R34 genuine N1's
934 John White, TAS 2001 Nissan Skyline GT-R V-Spec II N1
941 Peter Moore, 2002 Nissan Skyline GT-R V-Spec II N1
942 George Nittis, 2000 Nissan Skyline GT-R V-Spec II N1
were also R32 and R33 GTR N1 "replicas"
check www.targa.org.au for more information
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
