tacker Posted March 29, 2007 Share Posted March 29, 2007 How the hell do you snap the front of a water pump clean off! I now have two parts as it did just explode, so badly i could pull the whole front with the fan attached off the car with my hand??? Link to comment https://www.sau.com.au/forums/topic/162442-how-does-this-happen/ Share on other sites More sharing options...
Simon-S14 Posted March 29, 2007 Share Posted March 29, 2007 the fan belt has prob been way too tight for a while and has stressed the bearing, the pump is only alloy... so yeah while its not common it can happen. exp on a stock one thats done 100,000 kms with an over tightened belt Link to comment https://www.sau.com.au/forums/topic/162442-how-does-this-happen/#findComment-3017221 Share on other sites More sharing options...
tacker Posted March 30, 2007 Author Share Posted March 30, 2007 Hmm pump was only 60 kms old and belt was not all that tight, anyway chaly this one up to experience. Link to comment https://www.sau.com.au/forums/topic/162442-how-does-this-happen/#findComment-3017932 Share on other sites More sharing options...
Blitz Posted March 30, 2007 Share Posted March 30, 2007 Well, there is something I haven't seen before! No other damage as a result tacker? Link to comment https://www.sau.com.au/forums/topic/162442-how-does-this-happen/#findComment-3017988 Share on other sites More sharing options...
GeeTR Posted March 30, 2007 Share Posted March 30, 2007 Farrk me, thats incredible!! Theres a fair deal of webbed alloy meat in the snout. Condolences M Link to comment https://www.sau.com.au/forums/topic/162442-how-does-this-happen/#findComment-3018018 Share on other sites More sharing options...
dontfeelcold Posted March 30, 2007 Share Posted March 30, 2007 who put it in? Link to comment https://www.sau.com.au/forums/topic/162442-how-does-this-happen/#findComment-3018195 Share on other sites More sharing options...
tacker Posted March 30, 2007 Author Share Posted March 30, 2007 (edited) yer would you believe i was just sitting at the control light waiting for it to go green to start track session and bang! Engine was only idling thank F#$5. Radiator got a bit of a touch up from the fan and engine got a bit hot but not to bad would hate to think what would have happened at 8000 rpm? I put it in and before you say it i have been working on engines for the last 22 years and this is a simple task. Try putting an oil pump or an oil cooling nozzle into a Cummins KTA 50G3 which are both the definition of bloody near impossible. The pump had already done some track time with no problem then bang Edited March 30, 2007 by tacker Link to comment https://www.sau.com.au/forums/topic/162442-how-does-this-happen/#findComment-3018203 Share on other sites More sharing options...
dontfeelcold Posted March 30, 2007 Share Posted March 30, 2007 Who removed it from the previous vehicle? Link to comment https://www.sau.com.au/forums/topic/162442-how-does-this-happen/#findComment-3018257 Share on other sites More sharing options...
GeeTR Posted March 30, 2007 Share Posted March 30, 2007 Big Ass diesels huh? Maybe you accidentally used the same torque’ing figures? Just kidding - You were all thinking it M Link to comment https://www.sau.com.au/forums/topic/162442-how-does-this-happen/#findComment-3018264 Share on other sites More sharing options...
STATUS Posted March 30, 2007 Share Posted March 30, 2007 (edited) Its either an indian cheapy with casting issues (look for flaws, i cant see any in the pic though) or the belts were to tight. I have seen this happen to those copy SR20 sumps getting around small tap on a ripple strip and they literally fall off. Edited March 30, 2007 by URAS Link to comment https://www.sau.com.au/forums/topic/162442-how-does-this-happen/#findComment-3018280 Share on other sites More sharing options...
tacker Posted March 30, 2007 Author Share Posted March 30, 2007 (edited) yer big old smelly, nasty deisels. I am sure belt was not to tight still i guess that would be a reason for this happening but how tight must it have been to break that amount of cast alloy. And would that be possible with 1 little tensioning bolt. Pump was brand new when i put in on and i put the few kms on it without any issue, so it was never removed from any other engine. Thinking a N1 will now be put on as getting sick of removing cam belt etc to put pump in place only changed the last one as i put new cam belt on and thought i better do the right thing Edited March 30, 2007 by tacker Link to comment https://www.sau.com.au/forums/topic/162442-how-does-this-happen/#findComment-3018306 Share on other sites More sharing options...
SK1LNE Posted March 30, 2007 Share Posted March 30, 2007 did the bearing sieze? can you still turn it? Link to comment https://www.sau.com.au/forums/topic/162442-how-does-this-happen/#findComment-3018327 Share on other sites More sharing options...
tacker Posted March 30, 2007 Author Share Posted March 30, 2007 smooth as a baby bum lol! I must have done the belt too tight guess you live and learn. Link to comment https://www.sau.com.au/forums/topic/162442-how-does-this-happen/#findComment-3018357 Share on other sites More sharing options...
CEF11E Posted March 30, 2007 Share Posted March 30, 2007 there looks to be a fault in that casting Have a look a the left hand side between the 2 ribs. it looks like it is about 2 mm thick. was it a genuine pump? Link to comment https://www.sau.com.au/forums/topic/162442-how-does-this-happen/#findComment-3018429 Share on other sites More sharing options...
Simon-S14 Posted March 30, 2007 Share Posted March 30, 2007 maybe its been dropped somewhere along the line prior to you installing it? Link to comment https://www.sau.com.au/forums/topic/162442-how-does-this-happen/#findComment-3019637 Share on other sites More sharing options...
Fanta R33GTR Posted March 30, 2007 Share Posted March 30, 2007 The water pump in my GTR did exactly the same thing. The belt was just a little too tight and after a few weeks when I let her rip, it snapped and the pump was held on by only a small piece of metal. Like other have said, If it's not that then it's just a cheap pump perhaps with bad manufactering... Link to comment https://www.sau.com.au/forums/topic/162442-how-does-this-happen/#findComment-3019673 Share on other sites More sharing options...
tacker Posted March 31, 2007 Author Share Posted March 31, 2007 yer willing to believe to be ham fisted me that caused it. N1 water pump on the way. just got to remove the balancer, cam belt etc etc Link to comment https://www.sau.com.au/forums/topic/162442-how-does-this-happen/#findComment-3020146 Share on other sites More sharing options...
eSKiMo Posted April 1, 2007 Share Posted April 1, 2007 there looks to be a fault in that casting Have a look a the left hand side between the 2 ribs. it looks like it is about 2 mm thick. imagine how many pumps came out of the same cast! oh oh!! Link to comment https://www.sau.com.au/forums/topic/162442-how-does-this-happen/#findComment-3021700 Share on other sites More sharing options...
taynewguy Posted April 1, 2007 Share Posted April 1, 2007 Sounds like you got away with it ok though. This happened to me a while back in my r33 - threw the fan into the radiator at about 5000rpm. The fan had a few chunks missing from the blades and the radiator was cactus! We put it down to a fault/hairline crack in the water pump itself, as the belts were at correct tension. Link to comment https://www.sau.com.au/forums/topic/162442-how-does-this-happen/#findComment-3021861 Share on other sites More sharing options...
R31 POWER Posted April 1, 2007 Share Posted April 1, 2007 I'd be checking the clutch fan to see if it's seized. Link to comment https://www.sau.com.au/forums/topic/162442-how-does-this-happen/#findComment-3021975 Share on other sites More sharing options...
