Seen a white R33 with an LS1 over here in Perth, was built by a guy that went to jail for kiddy fiddling :)
I also found this photo somewhere on this site.. pretty sure I saw the car at Motorvation this year.. RWD 32 4door I think.
Thats the punishment for putting a V8 in a skyline, especially a non-nissan V8.
Seen a white R33 with an LS1 over here in Perth, was built by a guy that went to jail for kiddy fiddling :D
except that engine is a VG30DET v6, not a v8
anything can be done - im reading of a guy in the states doing a 350chev rearwheel drive conversion to fwd integra (rx7 IRS rear, ls1 engine, tremec t56 gearbox)
My bad.. I didn't look close enough.. I was distracted by that huge snail :D
JUST WANTED TO KNOW IF ANY ONE HAS EVER THOUGHT OF PUTTING A V8 INTO A 32 GTS4 OR GTR. JUST CRUIOUS TO SEE IF IT COULD BE DONE OR WOULD IT COST TO MUCH WITH HEAPS OF CUSTOM WORK. I THOUGHT IT MIGHT BE COOL WITH THE LOOK OF THE 32 AND THE SOUND OF A V8
"AN UNBELIEVER!!!! PERSICUTE... KILL THE HERETIC!!!!!"
Quote - Monty Python.
On a serious note dude, that is boardering sacrelig...
NA_R33 (John P) has a methanol injected supercharged VH45 running 10's. It was the one at jambo.
http://www.skylinesaustralia.com/forums/in...5764&st=320
and oh what a sweet ride it is... expect single digit runs soon!
That Red 34 with the Gen-TT LS1 is Australian.Built by GT Autosound in SA for the Drift Australia series, so it can be done. There is a few build pics on another forum. So it definately can be done, but i dont think u would get it done for less than 20k, alot of hours would be involved.
There is a bloke in the UK putting an LS1 into an Astra, so im sure with a bit of massaging you could get it in there no worries, just depend on how deep the pockets are, but if it makes you happy, then why not :stupid:
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
