Hi,
i want put a bigger turbo or hi flow the stock one? Which is better as i dont wanna change internals but want my engine not to blow or fry a piston. What is the best turbo for minimal lag, most power and a good amount of power at the wheels with standard RB25DET.
thanks
JOHN
If you're after response and good average power across the rev range, then I'd recommend a highflow - good bang for buck and should easily see 220-250rwkw with the right supporting mods.
If you have enough coin and are after more power whilst still maintaining decent response, then the HKS GT2835 ProS is also a good choice.
pfc + 740cc injectors + z32 + HKS GT2835 PRO S
Isn't 740cc overkill for anything under 350rwkw? 550cc injectors should be more than adequate.
Depends on how much power your after mate? and whether or not you may want more power in the future again!
again it depends on your supporting mods as well. sooner or later your going to need to change ur fuel pump, injectors, clutch, ecu...etc...and all of which costs more money.
imo, i'd go a HIFLOW. the hiflowed turbo will give you the best of both worlds, more power than stock and pretty good response as well. and best bang for buck!
my two cents,
goodluck mate
i would recommend the gcg hiflow, i had one of them on my rb25, got a vg30 ehxaust housing adapted to it and results were very good, i was more than happy with it. made 258kw at wheels on 15psi, my engine is built however but still expect a signifigant gain over standard turbo.
I'd go for a GCG highflow turbo. Personally tried and tested. Close to stock spool time, but huge power. It's ball bearing.
Bolts striaght up. No modding lines etc. Includes everythign you need e.g. gaskets, washers, etc etc.
Cheap -- 1750.
The precision turbo highflows in the group buy section are also good - 1550. ball bearing too. I personally haven't tested them, but I know people who have, and i'd get one.
ร—
ร—
