What are the best value and what do they cost? Next question where is the best place to buy them?
Also am going to need to run 10mm spacers with my new wheels. So will need spacers, i assume they must be bolt on. So is a there a good place for longer wheel studs or dont i need them for the bolt on type?
Bolt on type dont need longer studs (you might even have to cut them shorter if your wheel doesn't have the recesses in the back), but I dont think they make 10mm bolt ons, not enough meat to hold the studs. The thinnest I've seen is 15mm with 20mm being much more common. Just Jap sell the 15mm ones and they are hub centric which is helpful :D
Edited by salad
Troy,
I was chasing some hub centric bolt-on 10mm spacers for my gtst. Unfortunately 10mm is too thin for the bolts to be sunk into the spacer and are therefore unavail. The thinest bolt-on spacer I could find was a 15mm one from Kudos MS on these forums.
As for the wheel nuts....I'm using a set of Rays Daytona which are a hollow type (can see how much thread is being used) and have a rotating ring at the part that meets the rims which stops any damage being done to the rim if you over torque the nuts.
Cheers
So if i have a +40 wheel and need it to be +30 your telling me im stuffed?
For a bolt on spacer I'm afraid so.....you can get 10mm dodgy plate spacers though
Will the extra 5mm (ie 15mm bolt on type) really make a difference?
basically for 10mm spacer your only option is slip on. there are 2 types. the cheap arse ones, and the nice alloy ones that have an extra hub lip on them. either one is 'ok' but obviously one type is better! for 10mm spacers, I'd get 10mm longer studs too (well nismo make ones that are either 8mm longer, or 18mm longer). If you go bolt on you wont need new studs but you will almost certainly have to cut down your old ones which means they wont be any good if you want to take the spacers off again. but of course 15mm is the smallest bolt on spacer around. the nicest ones I've seen are the rays daytona ones. will have a look in the rays catalogue when i get home.
oh, and the daytona nuts are the shiznit! plus from memory they are 17mm hex which is handy if you have narrow 'holes' in your wheels which can make 19mm nuts a biatch.
I've got the other version of the Ray's nuts, but the extended long version so I could fit them over long studs if need be (ie taking spacers off). They're nice :D
Paid $200 for them new, but from a 'private' seller who had a few sets.
NISMO sells the 7-sided extended long version Lock-nuts
I bought a set when I was in their OMORI factory, basically all 20 of them are 7-sided lock nuts that would fit long studs.
They also have the racing version which has hollow centres.
hey hey i have some killer ones that just landed fully forged out of the same factory as the jap majors but half the price. not branded and shipped around the globe :(
what color? i think i have a sample silver set or black? here somewhere and also a whole lot of spare trust ones if you want the name on them :thumbsup:.
Edited by URAS
Troy,
Cheers
try gallop in nunawading, terracotta drive right next door to us. he has all the diff spacers and supplies most of the traders and wheel shops.
thankyou i have been looking for some nuts! which would fit my lm gt rims :happy:
    • Remember kids - if you can't afford to buy 2 GTRs......
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yep, its been down for a while, as I understand it it will be back soon.
