I Just popped into work to check on a couple of things and as i was leaving there was a huge accident ....I saw the whole thing and it wasnt pretty...It was on the intersection of mickleham rd and garden drive in tullamarine,1 lady was killed and one guy injured......the 4 occupants of the 32 got out pretty much uninjured......very silly circumstance's....
https://www.sau.com.au/forums/topic/163708-huge-crash-r32-gtr/
I saw a quick clip on the news before, did the GT-R have that paint that changes from various colours like blue to red to orange/green etc? I saw it had white wheels. I think it was at a show I had my cars at on Saturday, got taken for a drive in it.
the guy in the 32 ran the red and pulvarized the poor couple in the van
That really is tragic and need never have occured. I watched someone do the same 2 weeks ago and it is scary. The guy in my case, just wasnt paying attention, it hadnt even just changed to red as I had stopped and the car next to me had for a good few seconds. This falcon just hammered straight through and hit the guy turning right, accross his path on his green arrow.
Fortunately both were ok but a lot of damage, unlike in this case.
RIP :w00t:
Not sure what news you were watching...looked like a black 32 with silver multi spoke wheels to me...
I was watching the right news, car isn't black and clearly had white wheels.
It was the same car I saw on Saturday, had it confirmed, driver is apparently in hospital under police guard.
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
