Hello,
I am just interested in what everyone thinks of this tune....and if It good for road.
I asked for mid range punch....and everyday driving conditions......
I have not driven it yet....disregard old tune...boost controller was not set up correctly.
http://www.skylinesaustralia.com/forums/in...st&id=92010
https://www.sau.com.au/forums/topic/163761-is-this-a-good-tune/
All of the technical info is available in RB26 turbo upgrades.
http://www.skylinesaustralia.com/forums/in...80&start=80
Set up at 1.25Bar
Yes I know it is a bit wonky...this is why I am asking this question.
I have been told it is not on shoot-out mode......which is at 15km intervals on the graph...but at 5km interval,therefore plots are marked up and down.......making a more precise type curve
Your down around 50rwkw give or take i reckon aswell knowing your basically using 2530's
I have been told it is not on shoot-out mode......which is at 15km intervals on the graph...but at 5km interval,therefore plots are marked up and down.......making a rounder type curve
Have you even looked at the graph dude?
Its RPM based, not km/h based. :sorcerer:
I think someone is leading you up the garden path.
RPM and SPEED(KM's and hour) are both the same.
As for the 50RWKW I am under.....I believe his dyno needs to be callibrated...I have been told he is always 30 to 40KS's less than other tuning houses.
Im sorry, every dyno shop says their dyno reads lower, that way if you get more power somewhere else you cant blame them. Plotting is no different in shootout or non shootout mode. If their dyno reads low, dont you think they would be the first to get it calibrated? To be perfectly honest, i dont see how cars can be tuned to give a wavy power graph, on a power run it only goes through about 15 load cells, and as long as the numbers dont jump all over the place ive always found the curve to be smooth as long as there is no missfire. Can you get a graph of AFR's?
I stand by my comment about the garden path.
Definately sounds like someone is taking you for a run.
There are plenty of well known, proven workshops in Vic.
Just go to one of them
i can't be in shootout mode mate as it's not a dyno dynamics dyno. i have nfi if it's a good tune or not. maybe your engine has 60psi compression and the tuner did an amazing job just to get that power. on the other hand it could be a really good engine, with a really poor tune. and yes, every single dyno shop says their dyno reads low...
Id have to aggree with the up and down waves on the tune, usually they are alot smoother than that aswell, looks almost like up and down "fluctuating" boost in that area or wavey afrs whos to tell tho easiest also would be an afr curve and or boost curve may help in determining these things as well as barons comments its hard to say health engine or not
Thank you for your comments....I will try and get a afr graph and post it up soon....tuner will not be in town till thursday.
The state of the engine also has a lot to do with the max power.....I agree.
Was unaware that most tuners said that their dyno's showed lower readings than the others.....would have thought they would have the highest reading to lure the client back.(ie)"look at that great curve...look at that power I was able to tune in.."
When is the next Dyno day for SAU(VIC)...would love to see all the cars rated on the same dyno.
Dynamic Test systems are usually very good dynos.... every bit as good as Dyno Dynamics. That wavy section could be a myriad of things.... roller traction etc...
power for GT2530's is average though.
boostd mate. inlet cam and exhaust cam are two different things. you can't compare settings on his inlet cam to your exhaust cam. it's quite common to retard the ex cam and advance the inlet cam on rb26.
Whether the power curve is smooth or not can be a function of the scale of the dyno graph itself. Some tuners are known for making the vertical scale on a boost or AFR curve massive so the AFR and/or boost curve looks very flat.
In saying that I would expect more power everywhere with 2530's.
Yes, thanks for that. It's well known that retarding the exhaust cam will increase exhaust gas flow at low rpm in turn bringing boost on earlier, The advanced inlet cam causes a lumpy idle and better efficiency at high rpm....which can be seen on the dyno graph. I wasn't comparing the cams, but, what the different settings will acheive. His exhaust cam has been set at 0
Maybe the timing belt is loose and the cams would dial into in+2/ex-4 who knows, however comparing before and after graph lines its pretty obvious the tune favours top end by the shifted torque peak.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
