glad i found this topic!!! just bout to thro a haltech into the car and then lookin at turbo options of good power and drivability without having to increase the rpm!
was lookin at the gtrs hks turbos
Edited by Turbz_13
  • Replies 52
cruiseliner has had that username banned but he has the jun rb27 with To4Z, not the GTSS combo you mention :)
JustinFox is someone who had a thread recently about his GTSS dramas and then the solution.
justinfox is running 2530s mate. or at least he was.
Good results Nick as im telling you now on MSN... lol.
Here is part of the convo just for others, no point re-typing it.
GT-RS - 19/20psi
gt-rs 125km/h ~150rwkw
gt-ss 125km/h ~255wkw
gt-rs 150km/h ~255rwkw
gt-ss 150km/h ~300rwkw
Thats ~ 5200rpm
/end convo!
Anything after the approx 5200rpm mark and the GT-RS have caught the GT-SS and continue onto the bigger powers as you'd expect.
So you can see for a street GTR why the GT-SS dominate.
But for a drag or more hp aims, the GT-RS do well... Ill have a look for a good 2530 graph too, should be somewhere in the middle of the two
Whoops, sorry. They are GT-SS turbos "JA JUNG"+ funny jap clapping.
So 370rwkw from GT-SS turbo as 1.3 bar? Was that on PULP or race fuel? NOS?
Strikes me as being a little... well... optimistic unfortunately.
GT-SS are tiny-tot turbos of the HKS range.
Not much bigger than factory, around the same as R34 N1s.
When everyone makes 300-330rwkw from them, sitting around 20-22psi.
Then one car, just one... comes out and makes another 40-50rwkw from nothing doesnt add up at all.
If you said 2530's... it would be smack on the marker. But 370rwkw on PULP, thats very much unrealistic for GT-SS.
how do you think slides highflows would compare to the gt-ss in terms of response?
Without seeing them on a car with results, impossible to say
wow, thats a good post with good info from a person who can comment on both sides
i didnt think the GT-SSs could stay with the -5s so close, unless you mean the 20kw difference was the before and after cams with the -5s?
surprising is an understatement
go you little GT-SSs haha
Both set ups with the same Tomei cams 260/260 9,15mm nly the turboes changed
very interesting alchemist. basically the -5s have the same response as the SS and more power. can you refresh my poor memory with the specs/housings/part no. or the -5s?
just read back to your post alchemist. basically you are running the garret "2530" how different if at all is it from the HKS 2530? The only reason I ask is the HKS version is easier for me to get, and it comes of course with all the gaskets etc which save me some hassle.
Always a bit of a worry when you have stumped up for the cash & you start seeing topics like this.
http://www.turbobygarrett.com/turbobygarre...0R_707160_5.htm
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
