  • Replies 237
Posted Images
No Aaron to keep Jack honest. Ferni and Snowman need to steal some points from Jack, otherwise he is going to walk away with a big point slead.
So i have to ask Matt. What sort of poke has your thng got now? Extra 20-50rwkws? I fear the lil 20 may get left behind at Sandown.
Oh well, may aswell try and get 20 points this round, as I'm going to miss the next one in June...
The lil 20 will do well, PI proved that... :thumbsup:
Does it have to be that way or can you take princes on the left over the bridge as you come from springvale junction way?
Sometimes that is closed. safer to go sandown road. won't get stuck.
hahaha i don't expect to be anywhere near snowy or jack, first time out and lack of skill, you know.... Should be fun tho, i'm getting pumped....
Un-resolved as in it still wants to blow up above 7,000rpm.
Oh wells.....After all the dramas you've been having I only hope the the month or so break between this round and the next gives you time to sort it/
Edit: Found this Porsche Cayman S one on google videos, not to bad... still not super fast
http://video.google.com.au/videoplay?docid...7&q=sandown
ahhhh that looks scary around the back bends, theres no room for error at all! :mad:
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
