Does anyone know where I can get -10 black braided line? doesn't have to be anything special it's just for the breather lines.
I have found Pro Lite 350 Hose Has anyone had any dealings with this? Or know a good supplier as most prices I can find are around $60/Mtr
Edited by murrayis
  • 1 month later...
Ok a little bit of an update, Finished setting up the Haltech e11v2 and installed finally the Oil Catch Can setup.
Tried to turn it over today on what Haltech said should get it started as a Base Map not expecting it to fire and it didn't few nice Backfires and I decided to leave it at that
If anyone has a Map for a Haltech e11v2 for a rb25 with 750cc injectors I would be very grateful if I could get a copy to see if I can get the car running before I book the dyno and the tuner.
Anyway here is a quick Pic of the engine bay as it stands now.
Wheezy,
You are correct with a BMI 80mm Throttle Body.
Does anyone know what the firing angles for a rb20det are? I have them when I used a wasted spark setup but now I have the haltech I am not sure what the firing degress are.
Cheers
Cameron
Edited by murrayis
Wheezy,
Cheers
Cameron
120deg for an inline 6 IIRC?
Thats what I was thinking, I'll double check this with Haltech tomorrow just want to make sure as it seems when cranking to be popping weird as if the timing was all wrong.
Also need to get the type of CAS and if its on the Rising or Falling edge etc, I miss my Adaptronic where you could jsut tell it the engine and away it went lol
Cheers
Cameron
How do you find the KU plenum for response against the factory intake manifold? How is your top end also. I ask because I have one and have not spoken to anyone else who uses one on a 20. I just wanted to compare thoughts. Obviously the 2.4L will be a bit different, but close enough I guess :)
Wheezy,
Not having it fully tuned yet, results were pretty much as we expected its fairly responsive and flows plenty in the top end however I did port the manifold out to match the head and I also have 270 degree Cams.
Cheers
Cameron
Wheezy,
Cheers
Cameron
Interesting resultes, similarly; with my stock engine, I found it responded the same as a factory manifold but up top over 7,000rpm it keeps making power whilst an other RB20 I have seen with the same turbo drops off.
Cant wait to get some cams in it though.
Good luck tuning it! :thumbsup:
I Hate Tuners.... I spent 20 minutes yesterday trying to get it started, He sat in it turned the key and it fired up instantly!!!
And Yes the timing belt is a little too tight, Will have to back it off a tad.
Thanks again bubba for the Map.
    • Johnny is sad now... Because you didn't get Bosch Motorsport ABS.
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
    • So...not sure if you know if that has always been there or why you went looking. It could be old damage from a clutch explosion, or even just the gearbox got dropped somewhere along the line. Basically, you should seal it up to stop oil and dust getting into the bellhousing, but it doesn't matter too much and is not structural. I'd suggest something like a glob of JB Weld. BTW what gearbox oil are you running, I would guess the breather has been spewing it everywhere.
    • Hey Duncan thanks for your reply. Sorry mate I know the photos are shit.  Took another photo for reference. Seems the casing does have a hole in it looking on the net, fluid seeping out. Added a photo
