Give Gorden Levin Tyres in Emu Plains (Penrith) a call. They deal the tyres for alot of the motorsport categories in Australia and buy back a heap of the tyres after a race weekend so you can get some really good condition tyres for very cheap prices (under $100ea).
Now if only their A1GP tyres would fit under my rear guards :whistling:
Taleb tyres are doing sau'er specials for r888's for $120-$140 225.45.16 Just mention you are an sau member and be nice :sick:
Be careful of these. These are the hill climb tyres and are 3 years old and are from a large patch that were parallel imported. They are not really any good for circuit work as they will overheat.
Damn,
Are you sure? How do you know this?
I bought a set of these last weekend!!!
Oh well they should be alright for a few laps at a time (I hope). They do look pretty cool. I might have to put these on the car and try them on the street before I hit the track.
hmm, i'm not familliar with SG. When I last used the toyos there was G, GG and GGG. GGG was softest from memory. SG maybe one compound i'm not familiar with.
There's a Toyo Press Release (PDF) which talks about the parallel imported tyres. Basically what nfi said with more details.
Still does not explain what SG compound is for. The guys at Taleb tyres told me they where in between hard and soft compound. Now i'm not so sure?
It seems Taleb, St George and a few others were selling these specific tyres as I rung around and they all only had 225/45/16.
Who else bought these R888 (from Taleb, St George, etc) and who has tried them out yet? Feedback?
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
