  • Replies 95
ahah i wish.........your shell i bought 3 weeks ago was just for the rear cut i wanted.................come take it back if u want :) cause my beater decided that he didnt need it, after all that :spank: ........
so its just taking up space and my oldies are gonna :) me too because of u :)
how u going mate do u still have the dash instrument cluster for sale,ill give u $100 for it,where in sydney r u,would u be available for pick up today,my number is 0411 961 709
Edited by Browny_316
hey thanks for the offer but i will hold it for that,,, it has 69klms and sorry cant let it go for that...
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
