i have the 2530 strapped onto my rb20 atm with a few other supporting mods.
as soon as a dyno day comes around, it'll be on the dyno getting a power figure. hoping for around 200kwrw on about 1-1.1bar.
gotta sort out the running rich issue first tho.
  • Replies 97
Posted Images
Which ecu?
If you cant afford a pfc to fix the rich issue, try a SAFC?
Just for the record those HKS GT2535's are really just a 2530 with a slightly larger dinosaur 6/12 blade compressor tossed in because Garrett weren't doing the 71.1mm GT35 series compressors at that time like in later GT2871R/GT-RS type turbos . If you got a GT2871R 48T and bolted the HKS T3 flanged turbine (exhaust) housing to it you would have the same approximate deal with a more modern compressor wheel .
HKS got into Garretts GT ball bearing turbos early and for this reason had some combinations of mainly compressors that they don't use today . This is why turbos like 2510's , 2535's and 2540's are no longer made , better combinations developed with later thinking has made them redundant .
Roll on the twin scroll twin integral gate turbos like IHI is supplying to Subaru because they are the way of the future .
Cheers A .
My RB25 HKS 2535, combo made 244rwkw 14psi stock inj and AFM running a PFC.
I then bought injectors, Z32 boost controller etc, no more peak power but a massive amount of midrange was gained from 18psi... The extra boost totally transformed the car!
That same turbo is now on a mates car running 250rwkw at 15psi (i think) with the same setup (ECU, Z32 etc)
I also have another mate with a HKS 2535 on an RB25 with a Wolf 3D, injectors etc and he is running 18psi and 252rwkw...
I dont think they will run much more than 250ish rwkw no matter how much boost they have but the midrange agin on them is amazing at high psi...
I have one of these babies too on my rb20...made 202kwkw at 15psi with ths usual support mods...exhaust, fmic, fuel pump, z32, injectors and remapped ecu...theres a fair bit more left in it i just need a new front pipe as mine is dented and would be restricting flow...also have a 3" metal cat coming in the main to replace the sh!tty 3" cat i have...will turn the boost up and do another tune...then we'll see how it does....
Edited by limpus
Just to add a little further,
HKS 2530 equivalent = GT2860RS = 60mm compressor = 320hp rating
2535 = 69mm compressor = 350-370hp rating, no direct spec equivalent from Garrett
Garrett 2871 48T = 71mm compressor = 380hp rating, no direct spec equivalent released by HKS
Garrett 2871 52T = 71mm compressor with bigger inlet + T25 turbine flange pattern = 400+ hp rating = HKS GT-RS (but this has T3 flange pattern)
Running beyond a compressor's flow capacity will yield more midrange torque for sure, but run them into choke and as everyone's saying you won't make any more high rpm torque and possibly strike detonation issues unless the tuner takes strong notice of what the mechanical specs are and what information is being logged during the process.
Bottom line: do the numbers really matter, or what it does on the road?
Edited by Dale FZ1
robs was a 2535, not a 2530 :domokun:
my 2535 makes about 248kw @ 14-15psi according to what the dyno rekons.. allthough it does sound abit high.....
cln, rob told me no one ever believed it and he did it a number of times to shut people up..
Justin911 is now using that turbo.
And no it wasnt 25psi thru the turbo.
DjeMz: Robs tuning wont disapoint you :)
Im also using a HKS 2535 with a power fc, After market fuel pump, Splitfire coil packs 3 inch turbo back exhaust, GFB bleed valve standard injectors and sandard AFM on a RB25 R33 Series 1 the car pulled 240 rwkw at boostworks
Here is what you said:
djemz: rob from creatd is confident 2530s and 2535s are good for 250 and upwards.
with a 2530 he made 255 on his drift 33
When in fact 250rwkw is about the limit for this turbo; NO "upwards" :P
I just stated "260 is optimistic and any claims more is just BS"
Here is my Dyno graph with a before mentioned set-up.
Ignore the red line as the graph is a "b4 and after" comparison when i changed my exhaust system.
You can see where the cams and porting come into their own: More usable power and torque (better average power and torque)
I consider the GTRS as the newer version of the GT2535, as it only makes slightly more power and they stopped producing the GT2535 when the GTRS was released.
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
